I have a mkv video file encoded with dts audio that does not play on my media player. I read on forums that I can convert the dts to ac3 with is supported by my media player. I used txMuxer to demux the video and audio into two separate files. Then I use eac3to to convert the audio file from dts to ac3. Last, I use mkvmerge to combine the new ac3 file with the .264 video file. However, when I play the movie it is out of sync. The video is always slightly too fast. I have tried all the fps that is offered and it seems that 24000/1001 is the closet I can get and it is still about 4 seconds too slow. Any suggestions?
Use popcorn MKV converter for audio. will automatically mux streams back also. not had a problem here with same issue as yourself. worth a try. best of luck.
Mkvmerge has a delay function so use that if the audio is slight out all the time.
Ben Johnson-I didnt take any stereos!
a/v out of sync w/ mkvmerge
By runLoganrun in forum Video ConversionReplies: 14Last Post: 24th Dec 2008, 08:24 -
merging ac3, or wav
By kazz0817 in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2004, 08:38 -
Merging 2 *.m2V and 2 *.WAV or 2*.AC3 files to one
By petec in forum Authoring (DVD)Replies: 1Last Post: 12th Jul 2003, 08:40 -
merging 2 .ac3 files
By downer in forum Video ConversionReplies: 0Last Post: 4th Jan 2003, 17:38 -
Help merging .mpg with ac3 files for audio
By JermsW in forum Video ConversionReplies: 9Last Post: 30th Aug 2002, 15:07
Statistics
Newest guides
Latest tool updates
New media comments
