Wondering if it takes longer to convert an mkv file that has high definition video in it than one that has 480p video. I use avidemux to convert my mkv files for my ipod touch and some take 3-4 minutes while others take 9-10 minutes. Is this possible or do other factors affect speeds? Thanks.
Yes, it does. Compare a 352x480 encode to a 720x480 encode, even if bitrates are the same. It takes longer. Changing resolutions takes even more time.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Input frames size has a small effect on encoding speed. Output frame size has a large effect. Other factors have an effect too (complexity of video, encoder settings, etc.)
So going from a 1280 x 720 mkv file to a 480 x 272 mp4 file would take longer than if the mkv was a smaller resolution?
Yes. First the larger frame takes longer to decompress. Then it must be downsized to the new resolution. Both of those steps take time. Usually not a lot compared to the time it takes to compress the results though.
How much does resolution affect file size?
By milkydoo in forum Video ConversionReplies: 3Last Post: 16th Sep 2009, 18:29 -
mpeg2 to vcd : input resolution does not affect output !!
By koorosh in forum Video ConversionReplies: 19Last Post: 3rd Dec 2004, 05:46 -
Burn Speed affect quality?
By Smooth4evr in forum Authoring (VCD/SVCD)Replies: 21Last Post: 11th Oct 2002, 10:41 -
Do TV resolution/picture quality affect capture output?
By edumakation in forum CapturingReplies: 2Last Post: 10th Aug 2002, 00:44 -
How does resolution affect file size?
By N8theGr8 in forum Video ConversionReplies: 3Last Post: 21st Aug 2001, 15:02
