Hi there
I have some MKV files that were created by someone which contain two commentary tracks, one of which is in MP3 format. I tried converting them to AVCHD, using MultiAVCHD, which does a great job, but doesn't seem to convert the MP3 file?
I've tried playing the AVCHD back on my computers, as well as a PS3, yet there's no MP3 commentary. How can I fix this? is there any other software that will do what I want?
William
MKVExtractGUI to get the mp3 file out on it's own. Convert to AC3 2 channel 256 kbps. MKVMerge to put it back into the original MKV file in place of the MP3. Then try playing it back.
Are you sure it is MP3? Because multiAVCHD should reencode it to AC3. I tested a lot of files with MPEG1-L2 (mpa) and MPEG1-L3 (mp3) and it always worked.
Laugh and the world will laugh with you. Cry and you will be alone
The person who created the original file says it's in MP3
mediainfo the file and find out what is in it
You can also post the log from multiAVCHD - it will be much easier.
Replace .MKV Audio with Different Track
By Justron in forum Video ConversionReplies: 2Last Post: 1st Feb 2012, 17:03 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 06:03 -
Problem converting MKV files with a DTS audio track to DivX
By ryebeena in forum Newbie / General discussionsReplies: 2Last Post: 28th Nov 2009, 04:31 -
Gordian Knot AUDIO PROBLEM: DTS to VBR MP3? (HD 720p.mkv to SD XviD.avi)
By Randm in forum Video ConversionReplies: 2Last Post: 31st Jul 2009, 01:49 -
name of audio track in mkv
By shun in forum Video ConversionReplies: 1Last Post: 1st Mar 2009, 03:39
