Results 1 to 13 of 13
    I used a BNC-to-RCA Adapter to connect the TBCs BNC Video Out to the VCRs Line 2 Video In, but I don't see any difference in the video playback.
    What are you trying to accomplish? Usually you would use a TBC on the output of your VCR to clean up the sync. Or are you just trying to bypass macrovision so you can record something on your VCR?
    I'm trying to clean up the sync.
    You want to connect the output of the VCR to the input of the TBC, then the output of the TBC to your capture device.
    By capture device, you mean the DVD recorder?
    Yes. Assuming your intention is to record the VCR output with the DVD recorder.
    Alright then, just one question remains- how do I hook up the audio?
  8. Member edDV's Avatar
    You won't see much difference on a TV set for simple timebase correction. TV sets have fast horizontal lock and can respond line by line to VCR sync instability. DVD recorders and other capture devices react slower so line to line timebase errors end up in the recording. The TBC corrects these errors before capture.
    "Clean Up Sync" can mean many things. A TBC will usually replace H and V sync pulses clocked to either averaged input signal (consumer models) or an external reference (genlock). The stored lines are then output referenced to the new sync pulses.
    http://www.kiva.org/about
  9. Member edDV's Avatar
    The TBC should be placed between the playback VCR and the DVD recorder or capture card. Idea is to correct the VCR output before recording.
    I've got everything hooked up, and I can see the difference on the TBC (deffinatley worth the 60 bucks to clean up the transfer on my childhood Noozles videos), but I can't figure out how to hook up the audio. Can someone please help?
  11. Member edDV's Avatar
    Audio goes from VCR to DVD recorder.
    I still can't figure out the audio. Do the red and white cables go into the back of the VCR where it says "audio out", and into the red and white input plugs on the recorder? Because I tried that and it didn't work.
  13. Member edDV's Avatar
    It should.
    Check that audio is coming out of the cable. Plug it into an amp or TV.
  1. How do I hook up Hotronic ap41 to my VCR?
    By DaneClark in forum Restoration
    Last Post: 3rd Nov 2009, 16:33
  2. questions about Hotronic ap41
    By DaneClark in forum Newbie / General discussions
    Last Post: 28th Oct 2009, 20:45
  3. TBC choices; Hotronic AP41-SF for starters
    By videobruce in forum Restoration
    Last Post: 2nd Sep 2009, 10:36
  4. Hotronic AP41-SF service & owners manual needed
    Last Post: 2nd Sep 2009, 10:21
  5. Hotronic AR-31 TBC and VCR/VTR?
    By raminolta in forum Restoration
    Last Post: 26th Nov 2005, 02:20
About   Advertise   Forum   RSS Feeds   Statistics   Tools
