Searching these forums and google for the past 3 hours to no avail hopefully someone can help me out with this
I have a tv show I recorded through WMC that i'm attempting to convert to divx for storage, however I have nothing that will do this directly and I have to first convert the wtv file to a dvr-ms file. this isn't a problem in windows 7 (build 7600) however when I run the dvr-ms file the audio is all messed up (it's just static) and I can't figure out why.
Does anyone know what might be causing this? or any ideas on what else I could use to convert the wtv file to another format?
Any help would be greatly appreciated.
Thread: Problems with WTV
How do you convert to dvr-ms? what software?
Have you tried dvrmstoolbox?
And visit also http://thegreenbutton.com/forums/ , a good windows media center forum.
Right click > Convert to dvr-ms Format, checking out the forum now.
Also to add the files are 720p and 5.1 digital audio.
dvrmstoolbox doesn't help, converting from dvr-ms isn't the problem, the sound is fine as wtv it becomes static when converted to dvr-ms.
Is there a tool to demux wtv files?
Best Way To Batch Convert DVR-MS and WTV Files
By dj4monie in forum Video ConversionReplies: 35Last Post: 17th Nov 2011, 17:39 -
Windows Media Center .wtv 720p (60fps) to Xvid AVI (24fps) in Windows 7
By cg-realms in forum Video ConversionReplies: 0Last Post: 7th Jan 2010, 19:47 -
Converting WTV/DVR-MS to edit in Windows Movie Maker
By abw1987 in forum Newbie / General discussionsReplies: 8Last Post: 23rd Sep 2009, 06:58 -
media center .wtv ...
By iThinkYouBrokeIt in forum DVB / HDTVReplies: 3Last Post: 12th Feb 2009, 02:12 -
BIN problems, WMP problems, SVCD problems. Need help!
By felixunger in forum Software PlayingReplies: 0Last Post: 20th Apr 2004, 12:52
Statistics
Newest guides
Latest tool updates
New media comments
