I bought some DVDs (legally) that are Region 2 and won't play on my dvd player because they are Region 2.
They will play on my computer -- a Dell -- I guess because the DVD drive is not region-specific.
I want to read these onto my computer, convert to a non-region format or to Region 1, and then write them to a new DVD -- USING A MAC! My DVD drive on the Dell does not write, it only reads. My neighbor has a Mac that writes, but it won't read the DVD because of the region code. A mess.
So could I do this somehow:
- Read the DVD on my computer, convert to some neutral format
- Copy these files onto a USB drive
- Put the USB drive in the Mac, and write the DVD from there.
And can I do all this with free or low-cost software? I don't think I will ever be doing this again, so I'd rather not spend a lot on it.
Thanks!
Removing/changing the region code is only half of the battle. A simple copy of the DVD makes it region free. You need to figure out how to play PAL format videos on your American NTSC equipment...THAT will be your main problem to solve.
If you plan on watching more than one import DVD consider getting a region free, PAL/NTSC converting player like the Philips DVP-5990 or DVP-5992.
Ok, so the fact that it plays on my computer just means the computer can read the PAL as well as NTSC?
Since the computer can read and play it, can it be converted on the computer to MPEG or something, and then written back to a new DVD in NTSC?
What would be the software that could do this conversion?
Yes. Computers don't care about video formats.
Yes but....you can convert it to NTSC but it is not easy....especially if you want to keep the menus. I'd imagine it is even tougher on a Mac...I'm just guessing.
First of all, what country do the DVDs come from? Not all Region 2 discs are PAL. Japan is a Region 2 country, and it produces NTSC discs. If, by chance, your discs are Japanese, find a Mac-based DVD ripping tool. As an alternative, you could buy a DVD writer for your Dell and rip with a tool like DVDFab HDDecrypter. Even if the movie is PAL, it should play on your computer once it's ripped to your hard drive.
The DVDs are from the UK, and they do say PAL on them so that must be it.
Cheap DVD player with region hack
By hay7777 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 12th Dec 2006, 23:07 -
Converting Region 2 DVD Into Region 1 (or no region)
By casstk in forum MacReplies: 12Last Post: 3rd Oct 2004, 01:21 -
Newbie DVD Region Question
By jmcmike in forum DVD & Blu-ray PlayersReplies: 5Last Post: 8th Jul 2004, 07:45 -
Region Hacks or Cheap Region Free Players
By leebo in forum DVD & Blu-ray PlayersReplies: 3Last Post: 23rd Oct 2003, 16:00 -
Cheap Region Hackable Player
By in forum DVD & Blu-ray PlayersReplies: 0Last Post: 4th Dec 2001, 23:45
Newest guidesLatest tool updatesNew media commentsRecent DVD HacksDVDFab DVD to DVD lets you backup DVDs to DVDr, AVI or MP4 for portable devices. More info or download trial! About   Advertise   Forum   Forum Archive   RSS Feeds   Statistics   Tools
