Hi All,
I've some movies in .avi format, but want to burn them as DVD disc. So need to convert them into .VOB format. I've some softs, they are doing well, but increasing the size too big. suppose in .avi format 700 MB to .VOB format 2.5 GB!!!
Even from .avi to .mpeg size also increasing too bigger!!!
So, how can make dvd of those .avi files without changing size & quality?
~r
Just lower the video bitrate to get smaller size, in many tools can you also set the output file size. Use for example convertxtodvd, avstodvd, dvd flick.
BUT you can't keep the quality as dvd video needs higher bitrate=bigger file size to keep similar quality as avi divx/xvid/h264 video.
If you want to keep them the same size, get a DVD player that will also play Divx/Xvid encoded avi files, or get a WDTV and a portable HDD.
if you want to put them on DVD as DVDs, then it is one movie per disc (two if you use dual layer). Generally you need 3 - 4 times the original file size when converting to mpeg-2 to come close to maintaining the original quality (low as it is).
That's normal.Originally Posted by akakiami
Hi,
Sorry, but lately...I want to know something about film quality.
suppose, In our country, lots of "6 in 1 disk" movies available from Superbit collection in 7.81 GB, 1 disk. But, here film quality not bad (of course not as single disk). But as I told, if I convert .avi to .mpeg/.mpeg2, quality become very bad, although space increases from 700 MB to 2.5 GB.
But, how they are doing this? I mean 6 movies compressing (.VOB format) almost loosing film quality in 7.81 GB?
Changing the pixel size of Xvid AVI, but nothing else
By seaders in forum Video ConversionReplies: 10Last Post: 28th Jun 2009, 06:32 -
Converting from VOB to any other format - doesn't keep the original size
By Mylo in forum DVD RippingReplies: 5Last Post: 14th Mar 2009, 14:58 -
Best format for quality & size?
By DonGallego28 in forum Newbie / General discussionsReplies: 7Last Post: 21st Apr 2005, 12:02 -
changing cpu & mobo = HDD format?
By Red96TA in forum ComputerReplies: 7Last Post: 9th Oct 2004, 21:35 -
changing frame size of AVI file
By broadway in forum Video ConversionReplies: 0Last Post: 2nd Apr 2003, 00:44
