Hi,
I'm trying to get the best conversion from DVD to Premiere Pro (CS3) using Mpeg Streamclip to edit clips. I'm lost as far as what parameters to select after I choose Create AVI. Any suggestions would be helpful.
Huh? Premiere Pro is an NLE, MPEG Streamclip is a basic MPEG cutter. No relation.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Copy the content of the DVD to the HDD. Use VOB2MPG to extract the video and audio to an mpg file. Either load and edit this in Premiere, or convert it to Huffyuv or lagarith with virtualdubmpeg2 and edit in Premiere.
Thanks for the feedback. I'll try and be more clear.
I don't want to copy the contents of the (DVD) disk onto a HDD. I just need select clips. That's why I'm using Mpeg Streamclip...to go in and surgically grab the clips I want. I am already doing it, I just don't know the best settings within the (Create AVI) window to select for the best quality clip.
If it's a retail disc you can't just rip clips without removing copy protection first. You could use mpg2cut2 to "surgically" grab clips on non copy protected DVD's (or remove protection first by ripping it to your hard drive e.g. dvd fab, or "on the fly" with anydvd)
Best quality would be the original format (i.e. MPEG2) as guns1inger suggested or a lossless AVI intermediate (e.g. huffyuv or lagarith). The lossless intermediate takes many times more space
MPEG Streamclip, Final Cut Pro 6 and a DVD
By BovineofWar in forum DVD RippingReplies: 0Last Post: 28th Aug 2009, 11:47 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38 -
Mpeg-4 to mpeg-2 for mac/adobe premiere pro......
By macbookuser in forum Newbie / General discussionsReplies: 1Last Post: 4th Sep 2007, 22:48 -
Exporting with Premiere Pro MPEG-2 DVD problems...
By Mysticav in forum Newbie / General discussionsReplies: 0Last Post: 6th May 2004, 15:44 -
DVD WS2.0 AND MPLEXED AC3 AUDIO IN MPEG FROM PREMIERE PRO
By bombart in forum Authoring (DVD)Replies: 1Last Post: 15th Mar 2004, 12:13
