VideoHelp.com Forum
Results 1 to 9 of 9
    I am trying to rip a DVD to x264 mkv and preserving original resolution.
    I use DVD Decrypter, AutoMKV (and mkvmerge for adding soft subtitles).
    The source vob is 720x576 (2.35:1) says MediaInfo. In AutoMKV I check Anamorphic Encoding.
    The resulting .mkv becomes a 720x576 (16:9). But when played in mpc it gets more like 4:3 (with black bars on the sides) if I don't force 16:9.
    What am I doing wrong?
    Set the aspect ratio in MkvMerge.
    I have tried that with different values. It only puts black bars on the sides (bars that disappear when I resize the mpc window).
    It sounds like you have an MPC or MKV splitter problem then. Try another player.
    Yes it works in VLC but the image quality is then much lower. Other movies I downloaded works well in mpc with x264 mkv.
    Most of the other videos you download probably don't use anamorphic encoding (ie, they use square pixel). VLC shouldn't look worse than MPC. Are you using MPC or MPCHC? Do you have the Video Frame -> Keep Aspect Ratio setting enabled? And is Video Frame -> Touch Window From Inside selected? Also try enabling or disabling MPCHC's internal MKV splitter, and decoders.
    I was using good old mpc, with mpchc it works! Yes, the other files was HD content, no anamorpf for them I guess. Also yes on the other questions, can I conclude that mpc is to old to handle the file?
    Originally Posted by kramboa
    can I conclude that mpc is to old to handle the file? :)
    Maybe. It depends on the combination of MKV splitter and codecs you were using. Aspect ration information has to be passed from the MKV splitter, to the video decoder, and then to the video renderer (graphics card driver). MPC has fewer built in components and may rely more on DirectShow filters.
    Thank you for all your replies! I try to see the problem as solved, you can't be too picky when it comes to amateur video conversion:P
  1. Replies: 2
    Last Post: 22nd Nov 2011, 14:13
  2. MKV file displaying wrong aspect ratio on Bluray player.
    By djfonti in forum Video Conversion
    Last Post: 5th Sep 2011, 20:05
  3. Modify aspect ratio without re-encoding (x264)
    By MindBlank in forum Video Conversion
    Last Post: 29th May 2010, 09:50
  4. mkv to Blu ray gives wrong aspect ratio
    By Dragonsf in forum Authoring (Blu-ray)
    Last Post: 3rd Jun 2009, 01:47
  5. AVI to DVD aspect ratio always wrong
    By Focaldesign in forum ffmpegX general discussion
    Last Post: 26th Jan 2009, 18:18
