I have a Macbook and PC networked, and I would like to share the speakers I have for my PC. The speakers are a 4.1 setup with R/F 1/8" inputs. I've searching the internet for an audio splitter to do this, but I'm having a hard time finding anything. Any help would be appreciated.
So the speakers are physically connected to the PC and you want your MacBook to be able to play through them? Would it be only music you're playing through those speakers or do you need system sounds as well? If you're looking for a simple hardware splitter you can probably find such a thing at Radio Shack. Otherwise if it's a network sharing thing you'll need to find an app to support such a thing.
FB-DIMM are the real cause of global warming
yeah, the speakers are physically connected to the pc at this point. I want to be able to hear all sounds coming from the Mac. I'll be using the 1/8" out on the Mac to go to the A/B audio switch. I then plan to to run the F/R outs of the PC to the available inputs of the switch. Then run the F/R outs of the switch to the speakers.Originally Posted by rallynavvie
I've found R/L switches, but would they work for a F/R set-up?
F/R = front/rear? If the input/output of the switch is the same connection (1/8" phone jack) then I would think it'd be fine. Do the speakers just use a single 1/8" phone plug?
yup, front and rear. The speakers have two 1/8" plugs, 1 front 1 rear, with one end connected to the sub which powers everything. The other end currently going to the F/R on the pc. The out on the Macbook is a single 1/8".Originally Posted by rallynavvie
Not sure if you'll find something complex enough to split the single output on the Mac while at the same time accepting the multiple outputs on the PC. At least you'll be able to still get L/R when the switch is on the Mac. You can just run the rear connection directly from the PC and switch the fronts back and forth.
HDMI Splitter with Mac Mini Help
By Premo in forum Newbie / General discussionsReplies: 0Last Post: 28th Sep 2011, 01:06 -
HDMI Audio splitter for 7.1 into Receiver
By videohelpuser in forum AudioReplies: 2Last Post: 27th Apr 2011, 10:42 -
Gabest MP4 splitter vs. Haali Media Splitter
By jaduvil in forum Software PlayingReplies: 4Last Post: 16th Jun 2010, 11:57 -
Splitter for Digital Audio cable? 1 Amp but 2 devices
By thegeeman in forum AudioReplies: 2Last Post: 8th Feb 2010, 13:29 -
Podcast Audio Splitter(help)
By hellfire45 in forum AudioReplies: 5Last Post: 23rd Oct 2009, 15:30
