    I have a HDTV JVC Genessa and theirs only one audio output and no matter what receiver or wire i use the output volume is extreamlyy low ive looked through the tvs settings still nothing. Anyone have any idea??
  2. Member edDV's Avatar
    ATSC digital TV uses AC3 Dolby Digital audio. DD has wider dynamic range. That means the loudest loud is similar to analog sound but the soft volumes are way down.
    Most HDTV sets have settings for audio compression that lower the dynamic range (i.e raise soft volume). Cable boxes also have "audio compression" settings.
    This is sometimes called "night mode".
    http://www.kiva.org/about
  1. Low Audio Output
    By house141 in forum Mac
    Last Post: 18th Jan 2008, 00:16
  2. low audio output from WINAVI
    By djsqueeze in forum Audio
    Last Post: 9th Aug 2005, 03:56
  3. Low audio volume when output to TV
    By mnkyboy in forum Audio
    Last Post: 23rd Jul 2003, 11:46
  4. Low Audio Output
    By silenttalk in forum DVD Ripping
    Last Post: 8th Jul 2001, 02:09
  5. Low audio output
    By silenttalk in forum Authoring (VCD/SVCD)
    Last Post: 6th Jul 2001, 06:27
About   Advertise   Forum   RSS Feeds   Statistics   Tools
