I used VOB2MPGpro to convert a file from VOB to mpg. I only converted a couple of chapters and changed their order. The mpg file is ok for my computer but i cannot burn it on a DVD. Would appreciate any help.
costaseco
Thread: Cannot burn an mpg on a DVD
You can burn it, but it won't be standard DVD structure...Use DVDflick or convertxtoDVD to convert to proper DVD..they should not re-encode if the video is mpeg2 compliant.
Or you could de-mux the streams and re-author...Try
DGindex
DVDauthorGui or Gui for DVDauthor.."I typed the word Google into Google. Guess what came up? Everything."
"What we've got here is failure to communicate"
Got to ask this ... But dose your system have a dvd burner ?cannot burn it on a DVD
If not ... buy one
If yes, then ...
1: If issue is burning dvd discs then please included dvd burners make and model ... use [ur=http://www.gtopala.com/l]SIW[/url] ... reasonably simple to use, just go down to hardware > storage devices ... it will tell you if a dvd burner is installed, make, model, firmware revision ... include this in next reply
And also the dvd media's brand ... some are junk
2: If you meant burn to dvd where the home dvd player is unable to play it then the home dvd player may not either support direct mpeg2 playback or the issue is with the audio format ... best to convert to dvd ... plenty of applications availble from this sites tool section
Burn mpg on DVD
By knowmyname_20 in forum Newbie / General discussionsReplies: 3Last Post: 27th Aug 2007, 20:31 -
How to burn MPG onto DVD
By Italgreco in forum Newbie / General discussionsReplies: 2Last Post: 26th May 2005, 21:45 -
I want to burn two join and burn two mpg tracks as DVD
By drwho in forum Authoring (DVD)Replies: 2Last Post: 13th Mar 2005, 21:08 -
mpg to burn to dvd
By lilb93 in forum Video ConversionReplies: 5Last Post: 26th Nov 2004, 15:46 -
Mpg to DVD burn?
By flashbang in forum Authoring (DVD)Replies: 2Last Post: 23rd Jul 2003, 06:28
Statistics
Newest guides
Latest tool updates
New media comments
