VideoHelp.com Forum
  1. On the video tab in HDConvertToX I'm using a manually set bit rate of 4000. Is setting the Encoding Mode to "2 Pass" just a waste of time since it's a constant bit rate? I'm assuming that manually setting the bit rate is the same as CBR?
    I don't know HDConvertToX, but generally, just because you set a bitrate doesn't mean it's not VBR. Most encoders let you set the average bitrate for VBR. Some also let you specify the minimum and maximum bitrates. The average determines the file size.
  3. Hey thanks, that's pretty much what I was needing to know.
  1. 1 pass and 2 pass bit rate query
    By socrates in forum Blu-ray Ripping
    Last Post: 26th Nov 2010, 15:18
  2. Question about Bit Rate and Quality
    By T375 in forum Newbie / General discussions
    Last Post: 20th Sep 2010, 09:31
  3. XVID4PSP 6.0 2-pass, and Windows 7 64-bit question.
    By x2x3x2 in forum Video Conversion
    Last Post: 25th Jul 2010, 09:46
  4. How to achieve the maximum bit rate in variable bit rate mode ?
    By Sxn in forum Newbie / General discussions
    Last Post: 3rd Dec 2009, 12:53
  5. Simple bit rate question
    By Bully9 in forum Newbie / General discussions
    Last Post: 8th Jan 2009, 12:01
