I have a ReplayTV (similar to Tivo), and use mReplay to download TV shows to my mac. I downloaded a show, and want to edit it. It downloads as quicktime file, but I can't edit the file when I open it in Quicktime. The little edit arrows are not there. So I import it into MPEG Streamclip, edit the clip, and then export it. But the audio is not synced with the video. I've played around with it quite a bit and can't figure out what I'm doing wrong. On the export, the settings I am using are: Export to MPEG-4, Compression is Apple MPEG4 Compressor, frame size is 720 x 480 (DV-NTSC). I've tried limiting the Frame Rate and Data Rate but that doesn't solve the problem. Any ideas on why it's doing this, and how I can solve this problem. Please help. Thanks for your consideration. David
Results 1 to 1 of 1
Export Functions under MPEG Streamclip
By kannixpert in forum Video ConversionReplies: 0Last Post: 10th Feb 2011, 11:40 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Lost XviD export support in MPEG Streamclip after upgrade to Snow Leopard
By AVR2 in forum MacReplies: 3Last Post: 6th May 2010, 16:03 -
Tight synced audio + subtitles, poor synced video...
By goodbot in forum SubtitleReplies: 5Last Post: 13th Jul 2009, 22:59 -
MPEG Streamclip question: which is better? QT DV or Export to DV?
By Direwolf in forum MacReplies: 8Last Post: 29th Jan 2009, 11:38
