We have acquired a movie with the following description:
"Movie 1969 720p BluRay x264.mkv"
It is 7.94gb in size. We are trying to figure out a way to play it on a standalone dvd player or a standalone bluray player. We tried to convert it to avchd using the multiavchd software with the resulting avchd file way to big to fit on a doulble layer dvd. Is there anyway to play this on a standalone player with out losing quality?
Thread: mkv file too big for avchd
Split it or cut a bit using mkvtoolnix.
Or rerip from you original blu-ray...
thanks baldrick,
We will give it a try. We did not rip this, we downloaded it.
I use MultiAVCHD. Go into the Transcode area and put in the correct bitrate to make it fit, then re-encode and author. I use VCLAC to calculate bitrates.
gunslinger,
I could not find any info on your VCLAC on google, yahoo, wiki, etc. I did find VideoCalc in the tools section-is this the same thing?
AVCHD (DVD) .ISO file, trying to extract original MKV from DVD image
By SkEvolver in forum Blu-ray RippingReplies: 12Last Post: 11th Aug 2011, 06:55 -
No Audio On AVCHD-DVD, How To Remove Other Audio Tracks From MKV File First
By elistian in forum Video ConversionReplies: 1Last Post: 14th Dec 2009, 07:03 -
mov to mkv/avchd
By nirbhayn in forum Video ConversionReplies: 1Last Post: 19th Jun 2009, 15:33 -
Converting Mkv to AVCHD
By ranosb in forum Video ConversionReplies: 1Last Post: 9th May 2009, 06:25 -
By SkEvolver in forum Authoring (DVD)Replies: 1Last Post: 3rd Jul 2008, 21:34
