Hello,
I would like to know of any applications, preferably freeware, which I can use to cut select frames from an MPEG-1 file taken from 2 VCDs and then joined together. I want to get rid of the bit that says "End of Disc 1" and "Disc 2" at the beginning and end of each file, respectively. However, I only want to cut the frames with this text overlayed on the film because there is no audio during this portion. I am going to extract the resulting audio file without any silence in the middle at the join site and use it for another project.
As far as I know, TMPEGEnc authoring works 3.0 offers a one frame at a time splice feature in the cut/edit section, but the resulting file cannot be saved...it just becomes one of the tracks in the resulting DVD.
Any assistance would be greatly appreciated.![]()
Thread: cutting MPEG frame by frame
Womble MPEG Video Wizard
Womble MPEG-VCR
VideoReDo
TMPGEnc MPEG EditorAnswers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Here's how I did it back in the day:
I used ISOBuster to extract MPEG files then I used VideoStudio to edit and merge. One nice thing about VS is it can output 352x240(288) MPEG-2, it can also save audio clips.
Frame accurate cutting on m2ts files?
By stryker412 in forum EditingReplies: 3Last Post: 29th Jan 2012, 04:20 -
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 12:24 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
AsfBin: cutting by frame & container
By videohalp in forum EditingReplies: 3Last Post: 2nd Sep 2010, 00:48 -
Cutting AVI files by frame or keyframe?
By squegole in forum EditingReplies: 6Last Post: 1st Jun 2007, 12:25
Statistics
Newest guides
Latest tool updates
New media comments
