A strange thing happens with me in VDub ;
- I want to edit this chuck in VDub , its .ts file , so I created AVS script in MeGUI ... Imported it in VDub.
- I did the following :
1 - applied " Donald graft s smooth deinterlacer filter.
2 - cropped it with the shown values.
3 - encoded it as xvid video. .. the images shows what happened.
- Please download these files :
1 - The input chuck : 3.40 MB http://www.mediafire.com/?m4ghzmwykey
2 - The output chuck : 930 KB http://www.mediafire.com/?kftq2myyrzi
3 - the .AVS & .D2V files : 1.14 KB http://www.mediafire.com/?dezzm1yznam
The input image :
The cropping values :
The output image :
Notice the vertical line ...
Please note :
- I m used to do these steps , I always get no defects ... this problem appeared today , I reinstalled the operating system but the problem not solved ... I suspect the k-lite mega codec pack ( the last version ) ... the problem appeared when I used it ... there is another problem appeared when i used it ... when I open a folder containing .rmvb files the explorer freezes and says " explorer has encountered a problem an needs to close "
**** HOW TO SOLVE THIS PROBLEM ? What can u advice me about k-Lite Mega Codec Pack ? Is there any other pack behaves well ?
SORRY FOR prolixity.
Results 1 to 15 of 15
Thread: VirtualDubMod Problem??
ffdshow will open most video formats and it's not a codec pack but works similarly and rarely causes problems like codecs packs seem to do.
On my computer your AVI files plays with the same vertical bar at the right edge.
I duplicated your VirtualDubMod filtering sequence and got no problems:
duplicated.avi
But there is something wrong with your video. After cropping in VirtualDub you should have had a 712 pixel wide image left. But your AVI file has a width of 716.
Why are you using Crop(0,0,0,0) in your AviSynth script? And LanczosResize(720,576)? Your video is already 720x576.
Than Q so much 4 effort .... but may u tell me about the codecs installed on your PC? also , may u tell me your xvid presets in the duplicated file?Originally Posted by jagabo
I used Xvid-1.2.2-07062009. I think the version you are using simply doesn't like the frame size you are using (mod4 width, mod2 height). Note I added a bit to my previous post.
Than Q so much again ..Originally Posted by jagabo
* the problem is solved by using your recommended Xvid version.
* About resizing , there was another problem ; these vids are DVB streams recorded by satellite card " skystar2" ... In some channels , it gives me fake aspect ratio ... it is supposed to be 720x576 but actually when I put it in VDub or any other program the resulting aspect ratio becomes 480x576 ... so I decided to resize it in the script , but here u r right .. I was wrong to resize this vid.
- but about the buggy vids , Is it wrong to resize it by this way ? Is there any other way?
snapshot from VDub to the buugy vid
* I asked about codec packs on your PC if u use packs.
With MPEG encoding the frame size does not directly determine the display aspect ratio. MPEG files have a flag in them that tells the player at what aspect ratio the file should be displayed. Your sample TS had a frame size of 720x576 (a 5:4 ratio) but the proper display aspect ratio was flagged as 4:3.
There are two ways you can address this with Xvid encoding. You can resize the frame to a 4:3 ratio (like 640x480) and encode as "square pixel", or you can encode at any frame size and use Xvid's PAR/DAR flags to tell the player the correct display aspect ratio (4:3 in this case). It's generally safer to use square pixel encoding since not all players will respect the PAR/DAR flags. PAR is Pixel Aspect Ratio (the shape of individual pixels). DAR is Display Aspect Ratio (the final shape of the picture).
I don't use codec packs. I have ffdshow installed along with a few other specific codecs like Xvid, CoreAVC Pro, HuffYUV, Lagarith, Cedocida, and x264vfw.
* As u said , I solve the problem by resizing to any 4:3 aspect ratio & encode as " square pixel " .Originally Posted by jagabo
* Is there any difference between resizing with the VDub built in resize filter and Avisynth script resizing ?
* 720x576 & 720x480 (PAL & NTSC) always have 4:3 DAR ?? Is there any problem in conversion between them ?Originally Posted by jagabo
Once you load an AviSynth script, you should do all your filtering in AviSynth, not just the crop/resize but the deinterlacing and anything else. That way you can use Fast Recompress in VDub (rather than the slower Full Processing), and the encoding will go much faster and the the output quality will be slightly better because of no (or minimized) colorspace conversions.Originally Posted by 3thman
If for DVD both 720x480 and 720x576 can be set to encode as either 4:3 or 16:9.* 720x576 & 720x480 (PAL & NTSC) always have 4:3 DAR ??
Not sure what you're asking here, but in general the answer is 'no'.Is there any problem in conversion between them ?
MPEG 2 supports 4:3, 16:9, square pixel, and 2.11:1 DAR. 4:3 and 16:9 are the most common and the only two legal for DVD, I believe.
Thank u so much for response , "Fast Recompression mode" is very good Idea , but all avisynth deinterlacing plugins I ve seen are either extremely slow like" TempGaussMC beta1" or fast but gives lower quality .. so I use Donald Graft s Smart Deinterlacer.Originally Posted by manono
If U know any other Plugin that gives highest Quality & moderate speed , Please tell me about it ... the chuck is above U can Download it and try.
Another thing , In some vids I has to use "Region Remove filter" in VDub to remove the channel logo as I did in my Avi file , I cant do this in Avisynth. If u know similar filter in Avisynth , tell me about it
THAN Q AGAIN.
When I tried to download the Input Chuck it said this:
Yes, TempGaussMC is slow. Have you tried Yadif? "highest Quality & moderate speed " are pretty much mutually exclusive and highest quality is also the slowest.Invalid File. This error has been forwarded to MediaFire's development team.
I remove logos all the time, but can't suggest anything unless and until I see the video.
Sorry 4 bad link , these is the links
http://www.mediafire.com/?5mwzewmm1w1 ==> the ts file
http://www.mediafire.com/?bzbmmtgyl92 ==> the avi file
Thanks 4 interest
If you just cropped away the bottom, then there's no need to deinterlace it as the rest is progressive. Except for the last few frames and I'm not sure what's going on there, but your AVI still has the comb artifacts in those few frames also. The logo was removed fairly well from the AVI. Were you looking for something better? What did you use on it?
That line along the right side is most likely because of the screwy resolution you used. Try and make it at least Mod8 (both height and width divisible by 8) if not Mod16.
Here's my attempt at it:
http://www.mediafire.com/?ynngwdwmm2y
I could do a better job if there were a frame with a dark background to use to build the mask. The script used was:
InpaintFunc(mask="logo1.bmp",loc="TR",AR=4.0/3.0,mode="Inpaint",speed=10, ppmode=2,pp=100,radius=10.0,preblur=10.0)
Crop(0,4,0,-134)
LanczosResize(720,400)
http://avisynth.org/mediawiki/InpaintFunc
Be warned, though, that this filter is very slow.
Originally Posted by manonoI m so sorry 4 retard , Than Q so much again 4 interest ,Be warned, though, that this filter is very slow.
The vid u did is excellent , I did my vid by Region Remove filter ... I think i ll remain using it because it is faster , I ve tons of vids.
THANK U SO MUCH 4 YOUR EFFORTS
Problem with VirtualDubMod - what am I doing wrong?
By bahjan in forum EditingReplies: 2Last Post: 28th Sep 2010, 09:11 -
By darkdream4 in forum Newbie / General discussionsReplies: 8Last Post: 4th Feb 2010, 02:41 -
By raf.lanna in forum Newbie / General discussionsReplies: 1Last Post: 20th Jul 2008, 09:01 -
Virtualdubmod problem....
By aruwin in forum EditingReplies: 3Last Post: 20th Sep 2007, 07:41 -
By Mitchum22 in forum AudioReplies: 0Last Post: 15th Jun 2007, 11:28
Please note :
