Hello all,
I loved Ripbot! But after working well with version 1.14.3 I reinstalled my computer - then using the current version 1.14.5. I noticed that BD with DTS-Master were recognized by Ripbot as PCM (after demuxing) and the option x-copy did not show for mkv conversions. If I started a job it stopped after audio conversion (2-4 min) without any video conversion and no mkv output.
After switching back to 1.14.3 video conversion worked but the audio problem (cant x.copy DTS) remained.
If anyone recoglized this problem, please let me know how to correct it. Thanks in advance!
I attached a logfile for about 10% video conversion before stopping:
Syntaxfehler.
D:\>"C:\Program Files\RipBot264v1.14.5\tools\bepipe\bepipe.exe" --script "import(^D:\temp\RipBot264temp\job3\job3.avs^) " |
D:\>"C:\Program Files\RipBot264v1.14.5\tools\x264\x264_x86.exe" "D:\temp\RipBot264temp\job3\job3.avs" --pass 1 --bitrate 8192 --stats "D:\temp\RipBot264temp\job3\job3.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --sar 1:1 --level 4.1 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "D:\temp\RipBot264temp\video.264"
avis [info]: 1920x800 @ 23.98 fps (169801 frames)
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64
x264 [info]: profile Main, level 4.1
x264 [error]: ratecontrol_end: stats file could not be written to
x264 [error]: x264_encoder_encode failed
D:\>"C:\Program Files\RipBot264v1.14.5\tools\x264\x264_x86.exe" "D:\temp\RipBot264temp\job3\job3.avs" --pass 2 --bitrate 8192 --stats "D:\temp\RipBot264temp\job3\job3.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --sar 1:1 --level 4.1 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "D:\temp\RipBot264temp\video.264"
x264 [error]: ratecontrol_init: can't open stats file
x264 [error]: x264_encoder_open failed
D:\>"C:\Program Files\RipBot264v1.14.5\tools\mkvtoolnix\mkvmerge.exe" -o "D:\00_BluRay_Buffer\International\International.m kv" --title "International" --default-duration 0:24000/1001fps -d 0 -A -S "D:\temp\RipBot264temp\video.264" --chapters "D:\temp\RipBot264temp\job3\chapters.txt"
mkvmerge v2.9.8 ('C'est le bon') built on Aug 13 2009 12:49:06
Error: The file 'D:\temp\RipBot264temp\video.264' has unknown type. Please have a look at the supported file types ('mkvmerge --list-types') and contact the author Moritz Bunkus <moritz@bunkus.org> if your file type is supported but not recognized properly.
Elapsed Time: 01h:08m:54s
and here one with 50% video conversion before stopping:
x264 [warning]: width or height not divisible by 16 (1920x1038), compression will suffer.
x264 [info]: frame I:1462 Avg QP:20.62 size:191720
x264 [info]: frame P:72738 Avg QP:22.76 size: 51286
x264 [info]: frame B:53769 Avg QP:22.86 size: 26066
x264 [info]: consecutive B-frames: 23.1% 57.7% 9.4% 9.8%
x264 [info]: mb I I16..4: 43.5% 0.0% 56.5%
x264 [info]: mb P I16..4: 30.0% 0.0% 0.0% P16..4: 53.9% 0.0% 0.0% 0.0% 0.0% skip:16.1%
x264 [info]: mb B I16..4: 3.3% 0.0% 0.0% B16..8: 25.8% 0.0% 0.0% direct:30.2% skip:40.7% L0:27.6% L1:52.3% BI:20.1%
x264 [info]: final ratefactor: 20.30
x264 [info]: direct mvs spatial:97.5% temporal:2.5%
x264 [info]: coded y,uvDC,uvAC intra: 76.3% 50.9% 21.1% inter: 28.4% 16.8% 0.6%
x264 [info]: i16 v,h,dc,p: 25% 12% 39% 23%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 13% 19% 9% 9% 9% 7% 9% 7%
x264 [info]: kb/s:8112.23
encoded 127969 frames, 19.91 fps, 8112.23 kb/s
D:\>"C:\Program Files\RipBot264v1.14.5\tools\x264\x264_x86.exe" "D:\temp\RipBot264temp\job1\job1.avs" --pass 2 --bitrate 8192 --stats "D:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --sar 1:1 --level 4.1 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "D:\temp\RipBot264temp\video.264"
avis [info]: 1920x1038 @ 23.98 fps (127969 frames)
x264 [info]: profile High, level 4.1
D:\>"C:\Program Files\RipBot264v1.14.5\tools\mkvtoolnix\mkvmerge.e xe" -o "D:\00_BluRay_Buffer\BRIDE_WARS\BW.mkv" --title "BW" --default-duration 0:24000/1001fps -d 0 -A -S "D:\temp\RipBot264temp\video.264" --chapters "D:\temp\RipBot264temp\job1\chapters.txt"
'D:\temp\RipBot264temp\video.264': Using the AVC/h.264 ES demultiplexer.
'D:\temp\RipBot264temp\video.264' track 0: Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 1920/1038.
'D:\temp\RipBot264temp\video.264' track 0: Using the MPEG-4 part 10 ES video output module.
The file 'D:\00_BluRay_Buffer\BRIDE_WARS\BW.mkv' has been opened for writing.
The cue entries (the index) are being written...
Muxing took 72 seconds.
Elapsed Time: 03h:39m:36s
Thread: Ripbot behaving strangely
DTS-MA is decompressed to .wav (the same quality but in different form)
Uncompressed audio .wav converted to AC3 640 kbps will give you the same quality as DTS-core 1,5 Mbps. This is the reason why I do not extract DTS-core. 2,4 times larger file with the same quality does not sound logical for me. My knowledge is based on profesional tests made by independent group.
>>x264 [error]: ratecontrol_end: stats file could not be written to <<
replace x264_x86.exe with newer version
http://komisar.gin.by/x264.1318kGIT.generic.x86.exe
Thanks for the quick reply! (and thanks for writing that programm in the first place!)
I'll give it a try tonight!
Hello again! That was a partial success! The first two conversions worked fine but the third produced an error.
The only difference was that the sourecs that worked were thd, the failed job hat dts audio - but I did not confirm. The logfile looks like an error in video conversion (so much for the audio theory) - can anybody help?
Logfile as follows:
C:\>"C:\Program Files\RipBot\RipBot264v1.14.5\tools\bepipe\bepipe.exe" --script "import(^C:\temp\RipBot264temp\job1\job1.avs^) " | "C:\Program Files\RipBot\RipBot264v1.14.5\Tools\aften\aften.exe" -readtoeof 1 -b 640 - "C:\temp\RipBot264temp\audio.ac3"
BePipe by dimzon
Script used:
# BEGIN
import("C:\temp\RipBot264temp\job1\job1.avs")
# END
Scanning for Audio Stream...
Found Audio Stream
Channels=6, BitsPerSample=16, SampleRate=48000Hz
Writing Header...
Writing Data...
0%
Aften: A/52 audio encoder
Version SVN
(c) 2006-2007 Justin Ruggles, Prakash Punnoor, et al.
input format: Microsoft WAVE Signed 16-bit little-endian 48000 Hz 5.1-channel
output format: 48000 Hz 3/2 + LFE
SIMD usage: MMX SSE SSE2 SSE3
Threads: 4
progre
Done!
rate: 640.0 kbps
C:\>"C:\Program Files\RipBot\RipBot264v1.14.5\tools\x264\x264_x86. exe" "C:\temp\RipBot264temp\job1\job1.avs" --pass 1 --bitrate 8192 --stats "C:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --sar 1:1 --level 4.1 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "C:\temp\RipBot264temp\video.264"
avis [info]: 1920x816 @ 23.98 fps (127244 frames)
C:\>"C:\Program Files\RipBot\RipBot264v1.14.5\tools\x264\x264_x86. exe" "C:\temp\RipBot264temp\job1\job1.avs" --pass 2 --bitrate 8192 --stats "C:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --min-keyint 24 --keyint 240 --sar 1:1 --level 4.1 --aud --nal-hrd --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --direct auto --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --output "C:\temp\RipBot264temp\video.264"
x264 [error]: MB-tree frametype 245 doesn't match actual frametype 0.
C:\>"C:\Program Files\RipBot\RipBot264v1.14.5\tools\mkvtoolnix\mkvmerge.exe" -o "C:\00_BluRay_Quickbuffer\Jumper.mkv" --title "Jumper" --default-duration 0:24000/1001fps -d 0 -A -S "C:\temp\RipBot264temp\video.264" --language 0:und -a 0 -D -S "C:\temp\RipBot264temp\audio.ac3" --chapters "C:\temp\RipBot264temp\job1\chapters.txt"
Error: The file 'C:\temp\RipBot264temp\video.264' has unknown type. Please have a look at the supported file types ('mkvmerge --list-types') and contact the author Moritz Bunkus <moritz@bunkus.org> if your file type is supported but not recognized properly.
Elapsed Time: 01h:07m:52s
ripbot 1.17
By zero7404 in forum Blu-ray RippingReplies: 17Last Post: 27th Apr 2012, 11:25 -
RipBot v1.15.0?
By ajgoyt in forum Newbie / General discussionsReplies: 4Last Post: 3rd Mar 2010, 06:14 -
Strange Issue with Pinnacle 10.6 DVD Menus render strangely
By Kadji.Kahn in forum Authoring (DVD)Replies: 0Last Post: 26th Feb 2010, 14:47 -
ripbot
By jonno232 in forum Video ConversionReplies: 1Last Post: 18th Mar 2008, 22:50 -
How to fix this strangely encoded video?
By PTRACER in forum Video ConversionReplies: 19Last Post: 25th Sep 2007, 20:51
Statistics
Newest guides
Latest tool updates
New media comments
