    Is there any way to add filter to video without encoding or changing into another format with avidemux .Copying tracks and sync works without encoding.Why not filter ?
  2. Mod Neophyte Super Moderator redwudz's Avatar
    No. If you change the video through filtering or cropping or resizing you will have to re-encode.
  3. Always Watching guns1inger's Avatar
    [quote="tendra"Copying tracks and sync works without encoding.Why not filter ?[/quote]
    Because you aren't actually changing anything. Copying is a straight file copy of data from place a to place b. Sync adjustments are changes to meta data in the container, not the the actual audio.
    However once you start adding filters you change the actual video or audio data, and that requires re-encoding. This holds true for all editors and pretty much all effects and filters.
    Read my blogs here and here. Change England's Libel Laws - Sign Here
  1. Video Stabilizing Effect on Encoding Quality
    By Gargalash in forum Newbie / General discussions
    Last Post: 15th Sep 2009, 14:06
  2. Add new audio to DVD without re-encoding video??
    By vulture99 in forum Authoring (DVD)
    Last Post: 20th Nov 2008, 16:23
  3. Help for newbie I need to add a Tsunami effect to a video
    By coalfire in forum Newbie / General discussions
    Last Post: 28th Nov 2007, 16:27
  4. Replies: 7
    Last Post: 18th Dec 2006, 22:33
  5. Take TMPGEnc filters effect in CCE???
    By fabrice1979 in forum Video Conversion
    Last Post: 7th Oct 2002, 14:03
About   Advertise   Forum   RSS Feeds   Statistics   Tools
