I am editing AVCHD in Vegas for the first time and it is incredibly painful. Dragging the end of a clip to find a stopping point is very choppy. I used to edit MPEG-2 (.m2t) HDV all the time and it was so much faster.
I have a few codecs installed like K-Lite pack and CoreAVC, but I don't know if they're actually being utilized within Vegas. Even with quality set to absolute lowest (draft quarter quality) on my i7 6GB machine, it is still way too choppy to edit productively.
Using Win7 x64 and have both 32-bit and 64-bit versions of Vegas 9.
Thanks!
Results 1 to 10 of 10
no you'd have to convert to a lossless intermediate codec to make editing any easier. maybe neoscene would work for you.
So you're saying actually convert my media files before editing in Vegas?Originally Posted by minidv2dvd
Is my complaint pretty standard? Is it not possible to smoothly edit .MTS in Vegas with any consumer PC these days?
Try the 2 or 3 day demo of NeoScene and see if it works better for you. There are other options, but they are kludgy compared to Neoscene.
"Quality is cool, but don't forget... Content is King!"
http://www.kiva.org/about
What is better than a quad core? Dual quad cores? Not sure if the hyperthreading on my i7 helps...Originally Posted by edDV
Future CPUs. Use an i7 if you want the best now.Originally Posted by The111
Why don't you have a computer profile? If you are using an i7 and are frustrated, you only confirm my point.Recommends: Kiva.org - Loans that change lives.
Best to put your MTS file on a separate physical hard drive (not an external USB or firewire device), then feed the file to Vegas. Even better would be a Raid0 array.
Disk speed isn't the issue with h.264. The 1x transfer rate is only 17-24 Mb/s (2-4MB/s). Even a slow 5400 RPM drive can handle sustained 15-22 MB/s.Originally Posted by Soopafresh
The problem is h.264 takes a beefy CPU just to decode and play 1x. When editing you want to search/scan/scrub and that takes even more CPU even when only looking at I frames. Fine editing to the frame tales 3-10x scrubs and current CPUs just can't do that with h.264 so everything goes sticky and bogs down.
The digital intermediate formats convert long GOP h.264 to all I frames (larger file but still compressed). Cineform also randomizes the decode with wavelets for better filter or resize performance.
If you fully decompress, then yes, you need RAID to play 1x at 800-1,600 Mb/s (100-200MB/s) and 3-5x more for scrub.Recommends: Kiva.org - Loans that change lives.
Vegas Pro 9 get timecode from AVCHD
By flamadiddle in forum EditingReplies: 12Last Post: 6th Jan 2010, 16:40 -
Rendering AVCHD In Vegas Pro 8
By luisgmarine in forum Newbie / General discussionsReplies: 5Last Post: 27th Jan 2009, 01:03 -
DVD output from AVCHD and Vegas Pro?
By theaterguy in forum Newbie / General discussionsReplies: 2Last Post: 28th Oct 2008, 03:56 -
Problems with encoding AVCHD in Vegas 8
By Animy in forum Video ConversionReplies: 5Last Post: 19th Aug 2008, 16:24 -
Mixing HDV and AVCHD in Vegas Pro 8
By SCDVD in forum EditingReplies: 0Last Post: 9th Jun 2008, 19:29
