I have installed both the K-lite Mega Codec pack and also the CoreAVC codec, in that order.
I am playing back .MTS AVCHD footage from my CX100 camera on a top-of-the-line i7 rig, and it it pretty slow when skipping around in the timeline (WMP 12) to different parts of the video.
How do I know which codec is being used? I first had only K-lite installed, and it wasn't performing well enough, so I added CoreAVC (since I had heard it would be better), but it performs exactly the same. I have CoreAVC set as "preferred codec"... but I also have it set to show system tray icon and it never does... which makes me wonder if it's actually active.
Thanks!
Thread: How to tell active codec?
you could try gspot. load the file. down at the bottom click on ms av 1.
codec packs are notoriously bad. no one here would recommend anything but installing only the codecs you need one by one.
Then after creating the graph you can right click on the individual filters and see their property sheet or other details.
Thanks. Sorry for the slow reply.Originally Posted by minidv2dvd
So, I tried this out...
for a .m2t file, it only lists audio decoder... so what is it using for video decoder?
for a .MTS file, it lists (A) Microsoft DTV-DVD Video Decoder (B) DirectVobSub (C) Video Renderer
So does that mean it's not even using CoreAVC for the .MTS? And this whole "filter chain" concept... does this mean filters stack rather than replacing each other?
Try using GraphEdit or GraphStudio to build a filter graph. Just drag your video file onto the program window. It will show the filter graph:
You can right click on any filter to get its properties.
A graph like this is build by DirectShow every time you play a video. It examines all the installed filters (you typically have dozens, even hundreds) to figure out which ones can handle each of the jobs. If there are multiple filters that can perform the same job, say decode h.264 video, it takes the one with the highest merit (priority). You can adjust filter merits with a filter editor like Radlight Filter Manager, Filmerit, etc. GSpot also has the ability to change filter merits via System -> List Codecs...
The same video rendered in GSpot:
Any active moderators?
By thoughton in forum MacReplies: 9Last Post: 21st Jun 2005, 17:32 -
Stupid Active X
By gooberguy in forum ComputerReplies: 4Last Post: 23rd Feb 2005, 13:50 -
powersupply active PFC
By morr1s in forum ComputerReplies: 1Last Post: 19th Oct 2004, 21:55 -
active-max
By apurcell in forum ComputerReplies: 1Last Post: 29th Feb 2004, 03:38 -
active movie errors
By budgie59 in forum Video ConversionReplies: 1Last Post: 12th Feb 2003, 19:29
