  1. Member netmask56's Avatar
    A friend has ask me to fix his install of Corel VideoStudio 12. He installed it on a new computer running Windows 7 Ultimate and has a HD widescreen monitor. Basically it all works until the final stage where he can't get past the preview screen - there is no Next button! I've loded a few small jpg's that illustrate the issue. I have tried all the usual like running the program in Vista and XP mode SP2 and Sp3. Even tried Windows 2000! But nothing seems to be able to fix it. A thought could it be the 16:9 monitor? Must get hold of a standard 4:3 monitor to try. Any help most grateful. The first picture is how it looks installed and the one below is how it should look
    TheVoiceIsAnotherPerson ~ http://www.openwiz.org/wiki/ProjectX ~ BeyonWiz DP-P1 PVR + LiDiC ~ Popcorn C200 ~ Samsung LA40R7 LCD TV ~ Windows 7 & MAC G4
  2. Member MOVIEGEEK's Avatar
    Try changing the monitors resolution(eg 1024x768) or using ALT N:
    http://forum.corel.com/EN/viewtopic.php?t=35603
    Having problems ripping a DVD? Read my guide
    I have the same problem.
    The only thing that works so far to get me to next menu is pressing
    <Alt><N>
    You can then burn etc...
  4. Member netmask56's Avatar
    <Alt><N>
    Report back from my friend confirms Alt N works - thanks
  5. Member MOVIEGEEK's Avatar
    There's a patch to fix it now, it's the one dated 2009/11/10:
    http://www.origin.corel.com/servlet/.../1221854353274
  1. Rendering in Corel VideoStudio X2
    By Mattjsrules in forum Editing
    Last Post: 17th Sep 2010, 01:20
  2. Anyone familiar with Corel VideoStudio Pro X2?
    By brassplyer in forum Editing
    Last Post: 23rd May 2010, 11:00
  3. Opinions on Corel VideoStudio X2 Pro
    By Smack2k in forum Capturing
    Last Post: 12th Jul 2009, 00:32
  4. Corel VideoStudio Pro X2 effects
    By fayt in forum Newbie / General discussions
    Last Post: 25th Feb 2009, 12:18
  5. Corel Videostudio - How to add more themes?
    By samoyed in forum Newbie / General discussions
    Last Post: 28th Jan 2009, 20:14
About   Advertise   Forum   RSS Feeds   Statistics   Tools
