VideoHelp.com Forum
Results 1 to 9 of 9
Thread: Xvid4PSP
    Hey all,
    I just installed Windows 7 Ultimate and I was wondering why Xvid4PSP is now having issues with the audio. Every time I put a video up to convert and I test it out, the video plays with pixel marks and the audio is playing at super speed. Is there any requirement for proper functioning that I am missing. I installed Xvid4PSP 5.0.37.5 r2 (unofficial). Using the avisynth it has and everything else it has, then I installed the K-Lite Mega codec pack. Is it a net framework issue? or something else? any help would be appreciated.
    I have no problems with it under win7 ultimate. But then I haven't installed any klite pack...
    Do you get same problem whatever video source, profile and setting you use?
    Or maybe time to try something else, like HandBrake!
    Yeah no matter what setting I use it does the same thing. The volume is sped up. :/
  4. Member yoda313's Avatar
    Do you mean the audio is sped up?
    Are you trying to convert a pal video to ntsc? Could that be the issue?
    Yes, sorry I mean the audio is sped up and no, I am trying to convert an MKV into a MP4 for psp use. It used to work perfectly before I switched to windows 7 and then it just stopped working...is it cause i am missing Microsoft Net Framework? Or DivX or something?
    I had the same issue too on my Win 7 P.C, the audio was very fast. I tried it with the Windows XP Virtual mode, and it was fine. It must be a compatibility issue with 7, MS .Net Framework 3.5 is installed by default with Windows 7 and since it has a large codec pack (with the exception of .mkv) divx is not missing.
    I'm currently running the previous "official" version 5.036 with no audio issues.
    Codec packs are usually the problem.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    You can try the old versions, download from http://www.videohelp.com/tools/XviD4...sions#download
    Thank you all for your suggestions! I just installed the virtual XP mode and am currently using that with no issue. Thanks again for all the suggestions and taking the time to offer me some help.
  1. Xvid4psp help
    By skorpinok in forum Editing
    Last Post: 26th Jun 2011, 21:28
  2. Help with Xvid4Psp
    By xNesX in forum Video Conversion
    Last Post: 19th May 2011, 08:22
  3. Xvid4PSP - Help
    By Simmons in forum Video Conversion
    Last Post: 30th Mar 2011, 04:09
  4. XviD4PSP HELP!
    By jbird69 in forum Video Conversion
    Last Post: 13th May 2010, 22:45
  5. XviD4PSP
    By gjordan12198 in forum Video Conversion
    Last Post: 18th Dec 2008, 01:52
