I want to open this topic to "Video Conversion" section but rules don't allow it. Anyway. I'm nearly expert for video conversion but I didn't find any true info about solve of problem for convert vmw files with variable bitrate. I'm saying variable BITRATE, NOT variable FRAMERATE! Because these two are usually misunderstanding. I have a few videos, this is the one of them:
Format : Windows Media
File size : 370 KiB
Duration : 4s 0ms
Overall bit rate : 757 Kbps
Maximum Overall bit rate : 631 Kbps
Movie name : ta03
Performer : 岡崎硯次
Encoded date : UTC 2009-01-31 09:29:14.687
Video
Format : VC-1
Format profile : MP@HL
Codec ID : WMV3
Codec ID/Info : Windows Media Video 9
Codec ID/Hint : WMV3
Description of the codec : Windows Media Video 9 - Professional
Duration : 4s 0ms
Bit rate mode : Variable
Bit rate : 8 000 Kbps
Width : 800 pixels
Height : 600 pixels
Display aspect ratio : 4:3
Frame rate : 24.000 fps
Resolution : 24 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.694
Stream size : 3.81 MiB
Language : Japanese
Audio
Format : WMA Lossless
Format profile : M
Codec ID : 163
Codec ID/Info : Windows Media Audio 3
Description of the codec : Windows Media Audio 9 Lossless - VBR Quality 100, 44 kHz, 2 channel 16 bit 1-pass VBR
Duration : 4s 0ms
Bit rate : 134 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Resolution : 16 bits
Stream size : 65.3 KiB (18%)
Language : Japanese
I tried every way I know, but when I try to convert this video, result is always same. Out of sync.
Can I convert this video without audio-video sync. problem? Is there a way to convert variable wmv videos correctly?
Please help me! I beg of you!
NOTE:
1- VirtualDub's VBR fix mode doesn't work.
2- AviSynth's "EnsureVBRMP3Sync()" code doesn't work.
3- VBR MP3 different than VBR WMV, so ways for MP3 don't work for WMV.
4- I'll almost fr--king out.
Results 1 to 11 of 11
What kind of sync issues? Constant or progressively worsening?
What format are you trying to convert to? xvid/mp3/avi ?
Did you try convertfps=true using directshowsource? e.g.
DirectShowSource("video.wmv", fps=24, convertfps=true)
Are sync issues evident on that small sample that you used mediainfo on? If so can you upload it somewhere since it's so small
1- I don't know because this video is 4 second.
2- AVI (I think h264+mp3 or xvid mp3)
3- Yes I tried many many many times for different options.
4- Yes, here is the link:
http://rapidshare.com/files/300633545/ta02.wmv.html
What? Hmm, I think I understood you. You said, audio is constantly late or early from video OR audio going very different from video. I have long video too, but I can't try longer video yet. So let' sa that longer video has progressively worsening. What can I do?
Is the original WMV in sync? Are the clips from the same 24.0 fps source?
If progressively worsening, but in sync at the beginning, then the audio & video lengths don't match. (there would be no offset delay, because the sync is OK in the beginning). You would either shrink/expand the audio or video duration to match. If the source was actually 23.976 (instead of 24), this could explain the sync issues
First try this:
AssumeFPS(24)
Use CBR audio
Yes original wmv is sync. Yes all clips have 24 fps. No video and audio same time. And yes this code worked! (AssumeFPS(24))
I tried this:
with:
EnsureVBRMP3Sync()
And didn't work.
Now with your code issues are gone. (From now) [For 15 seconds movie and that 4 seconds movie]
Thanks for that. But I want to ask one thing:
You'll said: "First try this: ".
If this code didn't work, second?
Some WMV's are variable FRAME rate (VFR) , to help "fix" those (doesn't always work) , the convertfps is used
If the actual frame rate is 24, AssumeFPS(24) , will change the frame rate without changing the frame count. This is used after the source filter, because it makes the frame rate exactly 24000/1000 , not 24000/1001 or some other value. Some source filters return an "off" frame rate, and you can check your script using info() to identify the exact frame rate the script is returning
If you use
AssumeFPS(24, true)
This means sync_audio=true , and it will also change the audio sample rate to match (there might be a slight pitch shift proprotional to the change in rate from the original), but it looks like you didn't need to try it...
Anyways, you usually have to try a few options, and sometimes one of them works
Cheers
Many many thanks man. And I'm very sorry but I want to ask 2 thing.
1- Which converter you usually use? (With avisynth codes of course...[I use virtualdub])
2- Can I use this method for rmvb(real media variable bitrate) and Quicktime (some .mov videos have variable fps but constant bitrate)
1) I use vdub and megui for converting to xvid, megui and command line to convert to h264 (using x264)
2) Can you do this to convert FROM rmvb and QT => Yes, but for QT I would use QTSource, or FFMS2 instead of directshowsource. DirectShowSource is the least reliable and not necessarily frame accurate. It also is dependent on the system installed splitters and decoders, so prone to inconsistent results
How to Convert RMVB(Real Media Variable Bitrate) to AVI
By deletrius in forum User guidesReplies: 62Last Post: 5th Apr 2011, 08:36 -
Error in Variable bitrate (VBR) audio detected
By Russo in forum AudioReplies: 9Last Post: 12th Feb 2010, 08:01 -
Huge file after WMV to AVI conversion
By windranger in forum Newbie / General discussionsReplies: 8Last Post: 8th Apr 2008, 07:32 -
Bitrate question for Avi to Wmv conversion w/ Windows Media Encoder
By Gonz0ne in forum Video ConversionReplies: 5Last Post: 6th Jan 2008, 08:19 -
wmv to avi (divx/xvid) conversion jumpy output file
By famine99 in forum Video ConversionReplies: 5Last Post: 14th Oct 2007, 11:09
