VideoHelp.com Forum
  1. Member Shotobits's Avatar
    Hi, I'm trying to a copy dvd with nero 6, nero express, when I put a dvd disk to be copied in to my dvd-rom, my hdd activity led stays on and nero freezes, I can't turn it off, if I press ctrl-Alt-delete and click end program nothing happens,the only way I can get rid of it is to turn my pc off then reboot, I've tried reinstalling nero but it just the same, the dvd-rom drive seems to be working ok because it reads dvd's no problem, my o/s winxp 2gb ram, mobo asus M2M-MX, cpu AMD athlon 64x2 dual core 4400,
    The more you know the more you know that you don't know
    Have you tried copy with something else? Like imgburn. Same problem then?
  3. Member MOVIEGEEK's Avatar
    Is the DVD a store bought movie? If so it's encrypted and you need DVDFabDecrypter to rip.
    If it's a homemade DVD then just open the drive and drag the contents to a folder on your desktop. It's possible the disc has a lot of errors so try extracting with ISOBuster.
  4. Member Shotobits's Avatar
    thanks for your help, I got it sorted, I did a a firmware update and its working fine now
  1. DVD Burner Freezes When I Try to Copy a DVD
    By w6rlf in forum DVD Ripping
    Last Post: 7th Dec 2009, 13:41
  2. help nero freezes up during capturing
    By tomstr in forum Capturing
    Last Post: 24th Dec 2008, 22:29
  3. Nero Showtime 4 Freezes When Capturing A Frame
    By sbpyper in forum Capturing
    Last Post: 10th Jul 2008, 04:56
  4. Video freezes, audio continues in Nero
    By lj01 in forum Editing
    Last Post: 7th Apr 2008, 10:58
  5. burn with dvd decrypter but copy by nero ?
    By GINZY in forum DVD Ripping
    Last Post: 6th May 2007, 07:05
