Results 1 to 13 of 13
    Hi all,
    With 3:2 pulldown, 4 frames ABCD are converted to 5 frames (10 fields) AA AB BC CC DD. To IVTC the resulting video, I should say: combine the two fields of the first frame to get the original frame 1, combine the second field of the second frame and the first field of the third frame to get the original frame 2, combine the two fields of the fourth frame to get the original frame 3, and combine the two fields of the fifth frame to get the original frame 4. This way, the original video should be restored perfectly, they should be 100% identical. But as I read everywhere, this is not the case apparently (I read that artifacts can occur when IVTC is applied). But why does this method not work?
    Telecined video is often edited after being telecined. This can leave orphaned fields (a field where the complimentary field is no longer present).
    For example, in your example: AA AB BC CC DD the video could be cut between the BC and CC frames. The second part of the C frame is gone.
    Editing after telecine also means software may have to adapt to the changes in telecine pattern and may make mistakes. In fact, the simple fact that these issues exist means all the automatic IVTC algorithms are continuously looking for them. So even with perfect telecined videos they may occasionally make mistakes.
    Even worse, broadcasters will often reduce the running time of video by occasionally throwing out frames (to make room for more ads). Every time a frame is discarded there is a break in the telecine pattern.
  3. Member AlanHK's Avatar
    IVTC does work if the pulldown is perfectly applied: AA AB BC CC DD
    The artifacts arise when it isn't, when the sequence is scrambled, or other video is overlaid, if it's stretched or compressed, blended, etc, etc.
    Animation is notorious for weird framerates.
    That's why there are so many IVTC tools, Avisynth scripts, and so on.
    Okay, thanks. But if I have a 23.976 video and apply 3:2 pulldown to it, and I leave it that way, I should be able to perfectly IVTC it? And in this case, could this be done using the regular avisynth filters (such as separating the fields and combining specific fields to reproduce the original video)?
  5. If it's had pulldown applied then I assume you're doing this for DVD. In that case you don't have to IVTC at all. You just use DGIndex with the Field Operation set for Forced Film and get an already perfect 23.976fps D2V project file for use in your script. This applies to any progressively encoded MPEG-2 video with pulldown applied. You only have to IVTC the hard telecined or soft/hard telecine mixed MPEG-2 videos.
    Originally Posted by loekverhees
    But if I have a 23.976 video and apply 3:2 pulldown to it, and I leave it that way, I should be able to perfectly IVTC it? And in this case, could this be done using the regular avisynth filters (such as separate the fields en combine specific fields to reproduce the original video)?
    Yes, but what's the point when there's a much easier way?
    Thanks for that 'Forced Film' recommendation, I didn't know that.
    It was not my intention to actually use this method, I just asked it to be sure I understood it .
    Yes with something like:
    SeparateFields()
    SelectEvery(10, 0,1, 2,3, 5,6, 8,9)
    Weave()
    The exact SelectEvery() arguments will depend on where you start with the pulldown.
    Yes, but that "5,6" doesn't seem right.
    Shouldn't each pair be (even, odd) to select frames with the correct parity? (Or all (odd, even))
    AviSynth keeps track of which fields are top fields and which are bottom fields. It will weave fields 5 and 6 correctly. If you want you can reverse their order:
    SelectEvery(10, 0,1, 2,3, 6,5, 8,9)
    The end result will be the same.
    four film frames:
    A B C D
    2:3 pulldown:
    Aa BbB cC dDd
    paired into frames:
    Aa Bb Bc Cd Dd
    SeparateFields:
    A a B b B c C d D d
    0 1 2 3 4 5 6 7 8 9 (numbers for convenience)
    SelectEvery(10, 0,1, 2,3, 5,6, 8,9):
    A a B b c C D d
    Weave():
    Aa Bb cC Dd (AviSynth knows c is lower field and C is upper field and will combine them correctly)
    If the sequence is:
    AA AB BC CC DD
    01 23 45 67 89
    Shouldn't it be this?
    SelectEvery(10, 0,1, 3,4, 5,6, 8,9)
    If the sequence is:
    AA AB BC CC DD
    01 23 45 67 89
    Yes. That's why I said the exact pattern would depend on where in the pulldown you started.
    Okay, I understand.
    Ah, yes - thanks for clearing that up.
    The only slight oddity is that if written as (5, 6), the weaved frame will have a different parity (BFF or TFF) from the others inside Avisynth (visible via Info()).
    Of course, since the original footage was film, 5 and 6 represent the same moment in time, so their temporal order is irrelevant. Even so, for complete consistency it may be better to use (6,5) as it may matter under some obscure circumstances.
  1. Plays perfect on PC, but not so perfect on DVD Player
    By gmyers in forum Newbie / General discussions
    Last Post: 22nd Dec 2006, 21:12
  2. IVTC - What is the ivtc 'number pattern' for TMPGenc ?
    By vhelp in forum Video Conversion
    Last Post: 1st Feb 2006, 02:51
  3. Is a perfect IVTC possible?
    By j1d10t in forum Newbie / General discussions
    Last Post: 18th Aug 2003, 04:04
  4. How do you IVTC?
    By magnus in forum Video Conversion
    Last Post: 12th Mar 2002, 15:12
  5. IVTC, UVTC, we all VTC for IVTC
    By KoalaBear in forum Video Conversion
    Last Post: 22nd Aug 2001, 06:41
About   Advertise   Forum   RSS Feeds   Statistics   Tools
