I have donated and registered for the SVCD2DVD. When I click the icon and follow the registration instructions using the serial number information provided as instructed upon registration. After clicking register, nothing happens, the box disappears and I cannot run the software. If I click on the icon again, the same thing happens over and over.....Please advise.
Results 1 to 10 of 10
Thread: registration problem SVCD2DVD
1 try rebooting
2 try disabling your firewall
If your on vista right click on svcd2dvd and choose run as administrator. And it will register for you. I hope this helps.
Thank you both for your help:
lowell- i tried both and neither work. same thing happens
Wizard- when I right click, that is not an option. I go into properties and run as administrator is grayed out....run in separate memory space is checked. But this feature appears to be locked...any ideas?
Thanks Redwudz!!!
As you have vista - can you take a look at this thread about installation and Vista issues?
http://forum.videohelp.com/topic324278.html#1776530
(In particular: installation in a folder other than "Program Files" and running "As Administrator")SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
ChrissyBoy,
I cannot locate the exe file in the folder for SVCD2DVD v2.5. I do not think that it came over when I downloaded and installed this software.
I have an exe.config file, but I can't seem to open it. Is it possible that I can redownload and install it, without having to pay for this twice?
nevermind! Thanks got it to work.....Thanks for all your help!!!
Do you have "Hide extensions for known file types" enabled in Explorer?
(In Explorer, go to Tools > Folder Options > 'View' tab. Make sure the checkbox next to "Hide extensions for known file types" is not checked.)
Then, see if the .exe file is present in the SVCD2DVD directory.
(Edit: Oops, too late.
Registration for product SVCD2DVD
By flurcoop in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 26th May 2009, 04:21 -
SVCD2DVD registration
By brianbrian in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 1st Sep 2007, 15:08 -
Registration of svcd2dvd
By error in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 18th May 2007, 10:34 -
SVCD2DVD V2.0 Registration Problem-Internal Error!
By banny in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 17th Apr 2005, 14:54 -
SVCD2DVD registration problem
By Xero69 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Sep 2003, 04:25
