    I've been trying to open .mov files in ffmpegX, but they are always "unrecognized" by the software. OS X has no trouble recognizing these as Quicktime movies and playing them with Quicktime. What is going on here?
    Try mpeg streamclip. And if it works you can convert using it or convert to a format that you can use in ffmpegx.
  3. Explorer Case's Avatar
    What does QuickTime Payer's Movie Inspector (Cmd-I) say under Format? That is, what are the video and audio specifications?
    Where does ffmpegX say "unrecognized", in the Summary (format? video? audio?) or in the log?
    And when you download clips off a webpage, you should select Save as source, not Save as QuickTime movie, to keep the clip in its original movie container format. Then you won't get strange combinations like WMV3 in a .mov file, which other software might get confused by.
  1. Editing .mov files and .ifo/.vob files
    By redhot in forum Editing
    Last Post: 25th Nov 2008, 08:31
  2. MKV Support "Unrecognized" MKV files... ??
    By moon47usaco in forum ffmpegX general discussion
    Last Post: 11th Mar 2008, 21:59
  3. Unrecognized files????? quick easy question
    By spires in forum ffmpegX general discussion
    Last Post: 1st Dec 2006, 11:21
  4. Converted files are "Unrecognized" - New iPod H264 640x480 settin
    By rumplestiltskin in forum ffmpegX bugs and suggestions
    Last Post: 9th Oct 2006, 10:23
  5. unrecognized MPG files
    By namsilat in forum Newbie / General discussions
    Last Post: 27th Sep 2004, 21:39
About   Advertise   Forum   RSS Feeds   Statistics   Tools
