Results 1 to 15 of 15
    How does one author a PAL DVD using "mpeg-4 avc" NTSC 1280x720 VOB files?
    These were converted from mkv to vob, using mkv2vob, and play successfully as seperate 1gb vob files (same specs as mkv) in any player (powerdvd; vlc).
    Wish to play them as dvd's (fit 3 such onto one dvd?) through bluray player to large tv.
    Attempting many methods of demuxing, etc, to then place within "DVD Architect" - all fail.
    It is as if the H.264 codec at 23.976 1280:720p is not possible to code onto a dvd?
    Audio is classed as AC3 448KBs/48KHz/6ch
    any thoughts??
    For regular movie DVD you need to convert to MPEG 2 with legal DVD frame sizes and frame rates. For PAL DVD that is 720x576 at 25 fps.
    http://www.videohelp.com/dvd
    If you want to make AVCHD DVDs for playback on Blu-ray players (these will not play on regular DVD players) you need to author appropriately:
    http://www.videohelp.com/tools/secti...ring-bd-hd-dvd
    I'm pretty sure DVD Architect doesn't make AVCHD discs.
    thankyou so much - this is very useful.
    pointed the way to "avchd" program, which looks promising, resulting in no need for down conversion to lower frame resolution.
    investigation continues!
  4. Member obewon's Avatar
    MULTIAVCHD IS WHAT U NEED, ITS FREE AND CAN BE FOUND THROUGH THE TOOL SECTION.
    ITS VERY GOOD IVE USED IT LOADS
    I've just put the mkv 1280x720 NTSC files, through "multiAVCHD".
    Success!
    I simply burned the resulting two folders BDMV and HDAVCTN to a dvdr using imgburn.
    Plays flawlessly - with menu - on BDPS350.
    This will now be my standard method for transferring anything 'digital' to play through the S350.
    Thanks guys for the pointers - what a relief.
    (Maybe I only need to write the BDMV folder to the dvdr, as some have said?)
    p.s. annoying that four mkv 45min files at approx 1.145 GB each totals about 4.66GB, which seems too much for the "4.7"GB dvdr?
    the dvdr shows up as having a "capacity" of 4.36GB not 4.7GB.
    (by the tiniest amount)
    Or have i got this wrong - can I get the four of them onto the AVCHD dvdr, do you think?
    The difference is in how the term Giga is used. To disc manufacturers one Gig is 1000x1000x1000, or 1,000,000,000, bytes. To Windows 1 Gig is 1024x1024x1024, or 1,073,741,924 bytes.
    So a 4,700,000,000 byte disc only holds about 4.36 GB of data.
    yes this is very clear - thankyou.
    i wonder if there is some way to shave off the ends/starts/credits etc of each mkv clip somehow, within multiavchd,
    which would thus bring it down a tiny amount to 4.36gb
    Multiavchd offers this "start/end clip" mkv capacity, but annoyingly might be not enough to bring under 4.36
    perhaps easier to burn to the larger capacity dvd, with at least more mkv files.
    Not exactly what you're looking for, but it still might be useful to you. DVD+R has a slightly larger capacity than DVD-R - 4,700,372,992 vs. 4,707,319,808. It's not a lot, but if you're really close using DVD+R might be just big enough to keep you from having to edit. Another option would be to re-encode the audio to a lower bit rate.
    Do note that DVD discs tend to have problems at the outer edges. Many here discourage people from filling discs up to 99% or more capacity. On better quality media you may not have problems, but it sounds like whatever you do you're going to be pushing the limits of single layer discs. I'd advise using either Taiyo Yuden or Vebatim discs if you're going to be doing that.
    thankyou for this point, jman - much appreciated.
    And noted!
    Does anyone know if multiavchd stretches 4:3 avi/xvid files when transcoding to build its brd compatible disc-folders?
    the "tv room" display seems to suggest sadly that it would.
    i cant see a setting which says "retain 4:3 format".
  11. Select your file in MEDIA tab and click "EDIT". You will see "Title properties" window, then click "TRANSCODE". There are resize/aspect ratio options for the transcoding process.
    Dean
    Laugh and the world will laugh with you. Cry and you will be alone
    wonderful!
    but dean, if i have 21 files there all in 4:3 format, to be transcoded....... is there not "one setting" i can adjust which will apply to the whole disc? rather than doing your Edit method above for every vid file?
    your program is wonderful...thankyou.
  13. No, sorry
    sure thing, np.
    i'm going to try to put the 21 4:3 files through, with no extra transcode info inputted from me, and just see if will indeed end up displaying anyway in the same 4:3 format that they are in now as avi/divx, when played through the S350.
    thanks again.
  15. I'd suggest that you try one file and burn to DVD-RW for a test... just in case not to waste time.
  1. Guide wrong? "Converting a PAL DVD to NTSC using CCE"
    By OliverGrey in forum Video Conversion
    Last Post: 11th Jan 2009, 02:47
  2. Replies: 2
    Last Post: 12th Mar 2007, 11:23
  3. "Multisystem/PAL to NTSC/NTSC to PAL" in DVD playe
    By apakhira in forum DVD & Blu-ray Players
    Last Post: 11th Mar 2004, 09:03
  4. CAPTURE "MPEG-2" CONVERT TO "VOB"
    By chano8 in forum Video Conversion
    Last Post: 13th Aug 2003, 05:37
  5. How do i convert "BIN" files to "Mpeg"??
    By caTASHtrophe in forum Newbie / General discussions
    Last Post: 1st Jul 2002, 04:21
About   Advertise   Forum   RSS Feeds   Statistics   Tools
