Some time back, I got a Lightscribe burner that came with Roxio Creator 8.2XE to handle the label burning. Its worked quite flawlessly, and then I got real stupid.![]()
I noticed that the center window in Roxio Creator offered an update to 905u; so I clicked on it; it opened a download window, and I then saw that it'd be about 560-some megabytes.
I'm on rural dialup, and at 56K that would take about 28 hours, so I just clicked cancel... my 2nd mistake.
Now, everytime I start the computer (XPsp3), a Windows installer window opens and starts to configure the Creator update to install 8.2XE (which is the version already installed), and when I cancel it, the installer keeps returning- like 5 or 6 times, sometimes hiding behind other windows. Sometimes its called Windows Installer, sometimes Roxio 8.2 XE; usually it says Please wait while Windows configures Roxio 8.2 XE.
The original download window was not open long enough to acquire even 1 megabyte. Frequently the recurring Cancel window freezes and is unresponsive to Task Manager. I found something in Windows Prefetch, that is date stamped about right, its called ROXIO CENTRAL.EXE C:\WINDOWS\prefetch.
Roxio's site won't even give me a ticket...![]()
How can I remove the installer instruction from the Startup, or where ever it is?
Why did I do that? I didn't even really want an update...
Most likely you'll have to do some registry hacking.
Look under HKLM\software\microsoft\windows\run
then under runonce
See if it's loading there.
Might be a lot easier just to completely uninstall it and then reinstall from the original media
This little app will make it even easier
http://www.mlin.net/files/StartupCPL_EXE.zip"Quality is cool, but don't forget... Content is King!"
Start -> Run -> type in MSCONFIG -> press OK. Go to Startup tab, see if you can disable the program in question. It might also appear in the Startup group: Start -> All Programs -> Startup. If so, you can just delete it.
Need a direct download link for the Roxio 7.1.1.189
By wings123 in forum Authoring (DVD)Replies: 1Last Post: 10th Jan 2005, 11:59 -
With the whole Roxio Burn Movies on DVD thing..
By Frogger & Friends in forum DVD & Blu-ray PlayersReplies: 4Last Post: 11th Nov 2004, 19:34 -
Nero wont cancel and eject disc when I cancel burn
By danny333 in forum Software PlayingReplies: 5Last Post: 23rd Feb 2004, 04:32 -
how do I cancel the process
By guidorobben in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 17th Nov 2003, 08:02
Statistics
Newest guides
Latest tool updates
New media comments
