VideoHelp.com Forum
  1. On a SONY VAIO 3.2 GHZ running on XP and Imgburn 2.5.0.0 attempted to burn a DVD. The media is a MEMOREX DVD-R. Got the following error messages:
    "INVALID FIELD IN CDB" and
    "POWER CALIBRATION ERROR"
    Partial LOG follows:
    ; ImgBurn Version 2.5.0.0 - Log
    ; Tuesday, 27 October 2009, 22:43:50
    I 21:46:21 ImgBurn Version 2.5.0.0 started!
    I 21:46:21 Microsoft Windows XP Professional (5.1, Build 2600 : Service Pack 3)
    I 21:46:21 Total Physical Memory: 2,620,780 KB - Available: 1,641,664 KB
    I 21:46:21 Initialising SPTI...
    I 21:46:21 Searching for SCSI / ATAPI devices...
    I 21:46:22 Found 1 DVD-ROM and 1 DVD±RW!
    I 22:04:26 Operation Started!
    I 22:04:26 Source File: F:\Temp\dvd 2.iso
    I 22:04:26 Source File Sectors: 226,327 (MODE1/2048)
    I 22:04:26 Source File Size: 463,517,696 bytes
    I 22:04:26 Source File Volume Identifier: DVD_2
    I 22:04:26 Source File Volume Set Identifier: 4AE786340000000F
    I 22:04:26 Source File Application Identifier: MKISOFS ISO 9660/HFS FILESYSTEM BUILDER & CDRECORD CD-R/DVD CREATOR © 1993 E.YOUNGDALE © 1997 J.PEARSON/J.SCHILLING
    I 22:04:26 Source File Implementation Identifier: mkisofs
    I 22:04:26 Source File File System(s): ISO9660, UDF (1.02)
    I 22:04:26 Destination Device: [1:0:0] SONY DVD RW DW-U14A 2.0e (Z (ATA)
    I 22:04:26 Destination Media Type: DVD-R (Disc ID: RITEKF1) (Speeds: 1x, 2x, 4x)
    I 22:04:26 Destination Media Sectors: 2,297,888
    I 22:04:26 Write Mode: DVD
    I 22:04:26 Write Type: Incremental
    I 22:04:26 Write Speed: MAX
    I 22:04:26 Link Size: Auto
    I 22:04:26 Lock Volume: Yes
    I 22:04:26 Test Mode: No
    I 22:04:26 OPC: No
    I 22:04:26 BURN-Proof: Enabled
    I 22:04:26 Filling Buffer... (40 MB)
    I 22:04:27 Writing LeadIn...
    W 22:05:16 Failed to Write Sectors 2240 - 2271 - Reason: Power Calibration Area Error
    W 22:05:16 Retrying (1 of 20)...
    W 22:05:16 Retry Failed - Reason: Invalid Field in CDB22:05:16 Retrying (18 of 20)...
    W 22:05:16 Retrying (19 of 20)...
    W 22:05:16 Retrying (20 of 20)...
    W 22:39:25 Retrying (21)...
    W 22:39:25 Retry Failed - Reason: Invalid Field in CDB
    W 22:39:28 Retrying (22)...
    W 22:39:28 Retry Failed - Reason: Invalid Field in CDB
    W 22:39:29 Retrying (23)...
    W 22:39:29 Retry Failed - Reason: Invalid Field in CDB
    W 22:39:29 Retrying (24)...
    W 22:39:30 Retrying (25)...
    W 22:39:30 Retry Failed - Reason: Invalid Field in CDB
    W 22:39:31 Retrying (26)...
    W 22:39:31 Retry Failed - Reason: Invalid Field in CDB
    W 22:39:32 Retrying (27)...
    W 22:39:32 Retry Failed - Reason: Invalid Field in CDB
    W 22:39:35 Retrying (28)...
    W 22:39:35 Retry Failed - Reason: Invalid Field in CDB
    E 22:39:36 Failed to Write Sectors 2240 - 2271 - Reason: Power Calibration Area Error
    I 22:39:36 Synchronising Cache...
    I 22:39:45 Closing Track...
    W 22:40:31 Potential 'WaitImmediateIO' Deferred Error - (0/3) - Power Calibration Area Error
    W 22:40:31 Close Track Failed! - Reason: Power Calibration Area Error
    W 22:40:31 Retrying (1 of 3)...
    W 22:41:16 Potential 'WaitImmediateIO' Deferred Error - (0/3) - Power Calibration Area Error
    W 22:41:16 Retry Failed - Reason: Power Calibration Area Error
    W 22:41:16 Retrying (2 of 3)...
    W 22:42:01 Potential 'WaitImmediateIO' Deferred Error - (0/3) - Power Calibration Area Error
    W 22:42:01 Retry Failed - Reason: Power Calibration Area Error
    W 22:42:01 Retrying (3 of 3)...
    W 22:42:46 Potential 'WaitImmediateIO' Deferred Error - (0/3) - Power Calibration Area Error
    W 22:42:46 Retry Failed - Reason: Power Calibration Area Error
    E 22:42:52 Close Track Failed! - Reason: Power Calibration Area Error
    I 22:42:52 Closing Track (Last Attempt!)...
    E 22:43:37 Close Track Failed! - Reason: Power Calibration Area Error
    I 22:43:37 Closing Session...
    W 22:43:37 Close Session Failed! - Reason: Empty or Partially Written Reserved Track
    W 22:43:37 Retrying (1 of 3)...
    W 22:43:37 Retry Failed - Reason: Empty or Partially Written Reserved Track
    W 22:43:37 Retrying (2 of 3)...
    W 22:43:37 Retrying (3 of 3)...
    E 22:43:43 Close Session Failed! - Reason: Empty or Partially Written Reserved Track
    E 22:43:43 Failed to Write Image!
    E 22:43:43 Operation Failed! - Duration: 00:39:17
    I 22:43:43 Average Write Rate: 0 KB/s (0.0x) - Maximum Write Rate: 0 KB/s (0.0x)
    I 22:43:49 Close Request Acknowledged
    I 22:43:49 Closing Down...
    I 22:43:50 Shutting down SPTI...
    I 22:43:50 ImgBurn closed!
    I'd appreciate it very much any help, clues, hints.
    Thanks a lot.
    Armando
  2. Member MOVIEGEEK's Avatar
    Try another disc, if that doesn't work then try better media such as Verbatim.
    While you may try another disc or brand the error is a drive failure ...
    1: Download SIW, when running, hardware > storage devices ... burner model, name, and firmware is here, search sonys vaio website for any firmware updates for the burner ... it may be that its from another vendor in which case you go to their website and seek updated firmware from them ... reboot after and try another burn
    2: Failing 1 then If system is still under warranty ... return for repair (usually drive is replaced)
    3: Failing 1 and 2, you will need to purchase a replacement (burner) ... no, not a new laptop
  4. Mr. Computer Geek dannyboy48888's Avatar
    I know this may sound wierd, but I have seen more drives than not only support +r or -r media. so if you are failing with -r media try a +r disc . (i say -r because my drives give me this error with -r's)
    if all else fails read the damn manual
  5. Thanks a lot for your replys. The drive has the latest firmware update. I'll try a +r disc and pray. (smiles)
  6. Roadrunner JohnnyBob's Avatar
    You can uncheck the box for "Perform OPC Before Write" in ImgBurn (on the Settings, Write tab). It's not necessary.
    concisa,
    My advice would to either follow MOVIEGEEK's advice (use better media - Verbatim or Taiyo Yuden), or replace the burner.
    Even if the burner does work fine with better media, you still might consider replacing it with a newer burner, as it's from a different generation than most of the media you're likely to currently run across. As an example, the media you were having a problem with may say "Memorex", but it's actually "RITEKF1" which is 16x media. Your drive, however, has a maximum burn speed of 4x. Burning 16x media even at 4x (the maximum write speed for that burner) isn't going to be optimal. There's also a distinct possibility that the drive is using its' "gamble" write strategy (the drive doesn't know what to do with the newer media, so it's just using its' generic "best guess" write strategy)...which is also not optimal. A newer drive would burn a considerably wider assortment of available media, definitely more quickly, and generally with better quality. A new burner isn't likely to cost much, either.
    Of course, it's entirely your decision. As a firm believer in "if it ain't broken, don't fix it", I would completely understand if you would rather continue to use the existing drive...in which case, using something like the 8x Taiyo Yuden disks would be your best bet...or at least try to avoid media rated higher than 8x.
  1. Power Calibration Area Error
    By zork152 in forum DVD & Blu-ray Writers
    Last Post: 20th Jul 2009, 17:27
  2. ImgBurn Error Message
    By kwebster in forum DVD Ripping
    Last Post: 24th Nov 2008, 14:11
  3. Replies: 0
    Last Post: 25th Aug 2007, 16:41
  4. ImgBurn Error?? I keep getting this...
    By sandman423 in forum Authoring (DVD)
    Last Post: 2nd Jun 2007, 00:08
  5. Nero's "Power Calibration Error" fix.
    By AlecWest in forum Newbie / General discussions
    Last Post: 8th May 2007, 19:26
