Hi,
I've created a video with the N95 8GB.
It looks okay and I've edited with transitions, slowmotions etc. But I want to add another effect.
A VHS effect, like it's in the 90's.
Someone made this, and I want to do the same thing.
http://www.youtube.com/watch?v=ACmD-zkQ3c8
I couldn't find any tutorial or anything explained in this direction so I ask here
I know I can also record it to a real VHS tape and recapture but this time I want to try it with software.
The software I use is Vegas.
Hope someone can help me out
Results 1 to 9 of 9
Thread: VHS effect Vegas
The flag once raised will never fall!
The link you've provided won't work: invalid URL.
It link works now
It looks like an 80's video effect to me:
http://forums.creativecow.net/archivethread/2/506738
What effect is it exactly that you are aiming for? The glow around the person?
Thanks for the link.Originally Posted by MOVIEGEEK
I will play around with it. I quess there isn't a solution right?The flag once raised will never fall!
Actually everything wich makes a '90's effect, colors, brightness as much as possibleOriginally Posted by lowellriggsiamThe flag once raised will never fall!
If you are using Sony Vegas, the first thing you might play around with is the color curves. The effect in the video was likely done in front of a chroma screen, using chroma techniques. Chroma or Guiassian blur, and manipulated color curves.
I have made some experiments, I have to found just the right spot with the curves and the right combination effects.Originally Posted by lowellriggsiam
I've worked with curves in Photoshop, and succusfully edited photos.
tutorial http://veerle.duoh.com/blog/comments...vintage_effectThe flag once raised will never fall!
Sony Vegas how to make this effect?
By wingfan in forum EditingReplies: 0Last Post: 16th Jun 2011, 11:53 -
help with sony vegas effect
By cadogan in forum EditingReplies: 0Last Post: 21st Sep 2009, 16:59 -
Skin effect plug-in Vegas Pro?
By jnaizer in forum EditingReplies: 1Last Post: 16th Dec 2008, 18:39 -
Descriptions for Audio Effect Plug-ins-- Vegas 6.0d
By solarblast in forum AudioReplies: 4Last Post: 15th Nov 2008, 22:39 -
Snapshot effect in Sony Vegas?
By mashimiriam in forum EditingReplies: 1Last Post: 28th Aug 2008, 17:57
