    I presently have a Analog TV hooked up to my DVD Recorder (JVC DR-M10S,) which records everthing I want from Comcast Cable (Basic) for later viewing. If I were to get an HDTV, would I still be able to use it and with what result?
    Yes, you can use it, it will look the same as any other standard definition analog cable, DVD or antenna analog source.
  3. Member edDV's Avatar
    If you split the incoming cable to the DVD recorder and the HDTV (not daisy chain), you will be able to tune unencrypted HD QAM channels (e.g local broadcast and some cable channels) and watch in high def. Your DVD recorder will continue to see only the analog channels.
    You would connect the DVD recorder to the HDTV with analog component + audio cables.
    http://www.kiva.org/about
    No need to split. Just pass it.
  5. Member edDV's Avatar
    Varies model to model.
  1. HDTV Satellite & DVD recorder
    By taqman in forum DVB / HDTV
    Last Post: 31st Dec 2006, 14:31
  2. JVC M10S DVD Recorder region code
    By twoextreme4u in forum DVD & Blu-ray Recorders
    Last Post: 17th Aug 2006, 09:59
  3. Value of a DVD Recorder JVC DR-M10S?
    By scustalow in forum DVD & Blu-ray Recorders
    Last Post: 27th Apr 2006, 03:49
  4. JVC DR-M10S comments, questions & assorted rantings
    By piano632 in forum DVD & Blu-ray Recorders
    Last Post: 20th Dec 2004, 08:28
  5. VCR -> DVD Recorder (JVC DR-M10S) -> PC -> DVD+/-R
    By ckwok1 in forum DVD & Blu-ray Recorders
    Last Post: 15th Sep 2004, 23:20
About   Advertise   Forum   RSS Feeds   Statistics   Tools
