I currently have this Abit Motorboard with the integrated ATI Radeon™ Xpress 1250. It works ok but I have started watching a lot of Blu-ray movies and think the video quality could be better.
I'm thinking about buying one of these cards.
http://www.productwiki.com/ati-radeon-hd-4650/
http://www.newegg.com/Product/Produc...82E16814102819
Can some recommend something better then these video cards for around the $100 range or is this my best option? I need to video card to have on board audio processing as well.
Thanks.
Thread: Need Video Card Recommendation
if $100 is you upper limit (which quite frankly buys you a more than decent video card these days) then you may want to go a touch more upscale than the 4650 and get the 4670:Originally Posted by WPlotkin
http://hothardware.com/Articles/ATI-...he-Mainstream/
it has everything you specify you want and then some.
Does the ATI Radeon HD 4670 come with the DVI-2-HDMI adapter? Has anyone used an ATI card with this adapter does it work just as good as having it intergated to video card?
The video cards don't come with a DVI to HDMI adapter. Just pick up one those up from www.monoprice.com since they're very cheap. I bought one from them and it works well.
Gigabyte ATI HD 4350 w/HDMI, $34.99 (MIR card $24.99)
http://www.newegg.com/Product/Produc...82E16814125251
I use that Gigabyte video card with my E8400 system and it's hooked up to my 40inch LCD TV. It's a great inexpensive video card. If you game then get a ATI 4670 video card.
HIS H467QS1GH Radeon HD 4670, $74.99
http://www.newegg.com/Product/Produc...82E16814161287
Graphics Card Recommendation
By Imag33 in forum EditingReplies: 16Last Post: 28th Mar 2012, 23:18 -
Audio card recommendation please
By Zetti in forum AudioReplies: 1Last Post: 30th Jun 2011, 14:19 -
USB or PCMCIA video capture card recommendation.
By quetzalin in forum CapturingReplies: 0Last Post: 21st Sep 2010, 05:50 -
Recommendation on a graphics card for .MTS video editing and viewing
By Zetti in forum EditingReplies: 0Last Post: 12th Dec 2009, 23:07 -
Need recommendation for TV tuner card
By Djinn252 in forum Newbie / General discussionsReplies: 20Last Post: 27th Jul 2008, 03:30
Statistics
Newest guides
Latest tool updates
New media comments
