VideoHelp.com Forum
    Hello y'all experts
    I am currently recording clips with a Sony Mini DVD (MPG2) camera and editing the clips in Imovie 09 just to put a short intro and some subtitles. Unfortunately, the export quality of the clip is awful. The original MPG2 is quite good looking, albeit interlaced.
    My questions:
    1) Is there any alternative to Imovie that would let me edit the clip in the original MPG2 format, and insert the intro, etc, without a conversion? I know MPG2 is not a good format to edit, but maybe there is some solution.
    2) Would I benefit at all if I start using a camera that records in H264 ? Or Imovie would convert the clip to AIC and wreck the quality anyways ?
    Thanks a lot.
  2. hello
    Originally Posted by smartduck
    My questions:
    no you find some editiong abilities in MpegStreamClip (or Toast)
    they are very limited (trim, cut, paste) and not very user-friendly nor accurate … but they exist
    same behavior: mpeg2 or h264 are broadcasting formats
    AIC or DV are editing formats
    You need to convert every " broadcasting formats" to edit it safely (finally, it's only a temporary -huge- file for your edit)
    wrong, iMovie '08 or '09 doesn't damage your file if you don't use its presets.
    Every iMovie presets produce bad quality with interlaced files , so export to AIC from iMovie: huge resulting size, but you can process it later to a bradcasting format with a real soft (MPegStreamclip, etc)
    iMovie does not damage everytime, you just need to mislead it defaut behavior
    bye
    Some drawings ? http://www.whynotflores.com/. A software for DV, DVD-Video, HD files (AVCHD/…): http://www.movieconverter-studio.com/ 1.6 (2010/08)
  1. What form of h264 will VideoRedo h264 tvsuite accept?
    By Asterra in forum Video Conversion
    Last Post: 12th Apr 2012, 13:22
  2. Replies: 4
    Last Post: 11th Dec 2011, 20:05
  3. kiss 1600: how to make h264 work?
    By Kallo in forum ffmpegX general discussion
    Last Post: 13th Jan 2009, 11:36
  4. H264/AC3 (MKV) to H264/AAC (MP4) ?
    By jccca in forum Video Conversion
    Last Post: 13th Dec 2008, 19:06
  5. Replies: 12
    Last Post: 16th Feb 2008, 01:20
