VideoHelp.com Forum
    Hi,
    iam using unix avifile lib to convert YV12 Divx frame to RGB.
    I attach image of my outup. Left image is real frame from video and right image is my output.
    If you have any suggestions to solve this problem please post.
    Thx,
    wydesenej
  2. arithmetic without saturation - enable clamp, choose different color space coefficients
    more on this http://en.wikipedia.org/wiki/Saturation_arithmetic
    also problem with chroma planes (swapped Cb with Cr? looks like NOT or XOR values)
    It looks like your luma channel is being multiplied by 2 and isn't being clamped -- ie, when values go above 255 they are wrapping back down to 0. It also looks like the chroma channels are reversed. Here's your left image with the chroma channels reversed, converted to RGB, then all primaries multiplied by 2 (with clamping):
    Notice how all the dark areas are the same as your right image. The light areas are clamped here so they don't wrap around to black, they're just full out white.
  1. Premiere RGB exports produce bad frames - is YV12 a good alternative?
    By spicediver10191 in forum Video Conversion
    Last Post: 21st Feb 2011, 17:02
  2. 8-bit color RGB versus 10-bit color 4:2:2
    By fouronthefloor in forum Capturing
    Last Post: 9th Oct 2010, 06:20
  3. RGB 32 Color Output Playback Problem
    By Shone in forum Software Playing
    Last Post: 12th Nov 2009, 02:45
  4. Help with captured AVI: Vdub / HCenc / RGB / YUY2 / YV12
    By Rinsin in forum Video Conversion
    Last Post: 13th May 2009, 18:57
  5. DVD to DVD: YV12 to RGB to YV12, color problem ???
    By cd090580 in forum Restoration
    Last Post: 24th Oct 2008, 10:16
