VideoHelp.com Forum
    Hello all,
    what are your experiences with ffmpegX on 10.6 so far? It seems as if there aren't many or anyone around that are successfully using ffmpegX on Snow Leopard, if at all. I'd hate to go through the clean install process (and I wouldn't go any other route than this one) only to find out that ffmpegX would be broken. As it's relying on a couple of binaries too, and ffmpegX not being updated for quite a while, I'm curious …
    Thanks, Pat
    303
    I can't help the notion of ffmpegX becoming obsolete, given the lack of input regarding 10.6.
    303
  3. Explorer Case's Avatar
    Hi Pat,
    I'm running 10.4.11 PPC at home and 10.5.8 Intel at work. It is hard to comment on something I do not have access to. I am curious about 10.6 user's experiences, too.
    I expect ffmpegX to run okay for the most part, the binaries included. No so sure about ffmpegX's optional interaction with QuickTime, but perhaps it will work just fine or only need a few tweaks.
    Thanks Case. I think I read here about AppleScript errors occurring. What's up with mayor these days? Is ffmpegX going to be continued?
    303
    I'm running Snow Leopard with the latest version ffmpegX 0.0.9y and it works PLUS it is very fast.
    Have no fear of the snow.
    Y'all absolutely right. No probs encountered here, so far …
    On a side note, I've had problems replacing an MP3 file in a FinalCut Pro 7 project that I could track down to some sort of problem with QuickTime X. After installing QT 7 from the Snow Leopard Install DVD, that problem was gone. I assume that there may be problems related to QT X when QT 7 isn't available in your 10.6.x installation, so check that first if you encounter codec related probs.
    Thanks for your input!
    303
  1. tsMuxer for Snow Leopard
    By jangai in forum Mac
    Last Post: 10th Apr 2012, 20:25
  2. Will ffmpegX work in Snow Leopard?
    By visitor13 in forum ffmpegX general discussion
    Last Post: 24th May 2010, 06:22
  3. ffmpegX and Snow Leopard
    By drasw in forum ffmpegX general discussion
    Last Post: 8th Nov 2009, 10:09
  4. Garbled audio playback in snow leopard
    By several in forum Mac
    Last Post: 5th Nov 2009, 09:06
  5. ffmpegx/snow leopard applescript problem
    By jape in forum ffmpegX general discussion
    Last Post: 22nd Sep 2009, 11:00
