Hi all:
Most of the specialized people in this forum is suggesting Virtualdubmode to convert DVD to avi.
I'm trying but I have the following problem:
When I select the VIDEO_TS file it opens and there are a lot of VOB files.
What to do then ?? if I select one, only that one will be converted and my movie will not be totally converted !!!
Is there any way to select them all ??
Thread: DVD (VOB files) to avi
You use AutoGK.
In AutoGK you can select IFO for the Input file, that usually get the job for me if a DVD contain a single title. Or with VirtualDubMod you can convert to individual Avi files and append them to create a single new Avi title.Originally Posted by hilario
TS
Using AutoGK you can select the first VOB and the rest will be picked up automatically. No subs doing it that way, though.
Ok Thank you all.
I'm tryng with autoGK but I have the same problem.
Among all the vob files wich one do I have to select ??
Originally Posted by hilarioYou pick the first one in the VTS that contains the movie you want to convert to AVI, the VTS_0X_1. Of course, you should have used DVD Decrypter in IFO Mode or DVDFab HD Decrypter in Main Movie Mode to decrypt only the movie, and not everything on the whole DVD, but maybe you'll be OK.Originally Posted by manono
Ok Now I understand.The problem is that I got the DVD from internet.
tks.
Making a DVD with both .vob and .avi source files?
By dastott in forum Authoring (DVD)Replies: 9Last Post: 23rd Nov 2005, 06:36 -
Help needed converting AVI > DVD @ VOB files
By verderacer in forum MacReplies: 2Last Post: 10th Jan 2005, 11:51 -
Rip DVD VOB files to single AVI File....
By jingjing in forum DVD RippingReplies: 1Last Post: 28th Jun 2004, 00:00 -
avi,mpg to dvd vob files?
By stizzla in forum Video ConversionReplies: 1Last Post: 20th Jan 2004, 20:32 -
Converting AVI to DVD (VOB files) - what tool do I want?
By Ronaldus in forum Newbie / General discussionsReplies: 7Last Post: 26th Dec 2003, 15:29
