VideoHelp.com Forum
    Ok, I have several .wmv files that need to be joined to make 1 whole movie. But first they need to be split as the videos are in several parts and they have an intro of roughly 2 seconds that needs to be removed. In the past I had success with Boilsoft Avi/mpeg/wmv splitter and joiner.
    For some reason it quit working properly. By properly I mean when you load up the video in the splitter and type in the "start time" box you could do it down to the 100th of a second to completely cut the intro out without going into the video and when they were all split and joined it would be a near seamless merge.
    The splitter won't allow it to preview where you were at with the time you set in the box where it did before. I just get to look at the opening intro that I need cut off.
    After giving up on it and just holding onto the vids until I needed to do a windows re-install I tried again having the same results.
    I even tried another splitter called "Easy Video Splitter" that seemed to have the same features as the Boilsoft splitter but it also would not allow me to seek in the video. Both splitters though show the slider bar move forward when you enter whatever number of seconds you want it to.
    So I'm stumped. Any other splitters I should try or could it be some type of missing codec? Thanks for any help!
    Try asfbin.
  1. Splitting MP4
    By rocks911 in forum Editing
    Last Post: 1st Mar 2012, 23:11
  2. Splitting up a video?
    By bartman99 in forum Mac
    Last Post: 27th May 2010, 08:13
  3. How do I keep DV files from splitting ?
    By RWANDREWS in forum Capturing
    Last Post: 15th May 2010, 03:07
  4. Splitting with MKVmerge
    By carlmart in forum Video Conversion
    Last Post: 22nd Dec 2009, 19:59
  5. cutting and splitting
    By ichigo15 in forum Editing
    Last Post: 18th Jun 2007, 20:01
