I need a player that can play a dvd frame by frame, backwards also if possible.
I tried Media Player Classic, but when I print screen and paste the image in photoshop, the image does some weird stuff...so media player is not suitable. I also can't get it done neither with VLC, nor with wmp.
Any other suggestion?
Thanks![]()
Results 1 to 10 of 10
Thread: Frame by frame dvd player
You're just looking for single frame caps?
You can try virtualdubmod
Wow...that was fast!
I don't know if i did something wrong, but the quality is ugly...
Yes i'm looking for single frame caps
quality from vdubmod is "ugly"?
can you describe what you mean? or post the screenshot?
is your dvd interlaced?
In virtualdub, you can use IVTC filter if it's telecined, or deinterlace filter if it's interlaced. Then Ctrl+2 to copy output frame
If it's another pattern or blended DVD, then you can use avisynth to process it
Vdub/vdubmod aren't players, they are meant for editing
There are no good players that support single frame navigation that I know of, and it depends on your splitter/decoder used. KMplayer can go fwd 1 frame using the "f" key, but backwards doesn't work so well
Are you playing this from your Hard Drive or DVD-ROM? It looks like copy protection. Did you use anydvd or dvdfab?
Seems like a fuss, edit the video first and then playback.
KMPlayer does the exact same thing with Media Player Classic when I insert the picture into photoshop... Inside it, when i resize, rescale the window, the image stays intact
What weird stuff? aspect ratio? describe what you mean, because my crystal ball isn't working today
The picture taken is the same size 1:1, the media player's don't take rescaled images. If you want to scale it, do it in photoshop.
Sorry for the delay
I can't even capture it on screen. I can only describe it. Anything I do, move the frame inside photoshop, rescale it, the captured image from the movie stays intact, like it's stuck on the screen and the frame is just a transparent thing.
I hope you get what I mean now, because I encountered this with every player that plays the movie forward frame by frame. KMPlayer, Media Player Classic, and PowerDVD
Your file is corrupt or you have codec problems.Originally Posted by IllusionOfLife
VirtualDub and VirtualDubMod let you scroll forward and backward one frame at a time with the arrow keys.
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 23:53 -
Problem with frame (have small frame, want bigger frame)
By jimbo321 in forum Newbie / General discussionsReplies: 15Last Post: 15th May 2006, 09:43 -
MPEG media player allowing frame by frame viewing
By hard_hook in forum Newbie / General discussionsReplies: 1Last Post: 26th Feb 2006, 21:22 -
Frame by frame DVD viewing
By darksea13 in forum MacReplies: 4Last Post: 25th Mar 2004, 21:57 -
Moving Media Player 9 frame by frame
By unrealityman in forum Video ConversionReplies: 0Last Post: 4th Nov 2002, 06:51
