Results 1 to 10 of 10
    In Premiere cs3 the video in the preview screen moves slowly & does not synchronize the audio ... In Premiere cs4 it freezes & does not move while the audio runs well.
    I have 2.55 GB free space on C drive & 1 GB ram
    How to solve this problem ?
  2. Member edDV's Avatar
    What is the source video format? Is it supported by Premiere CS3?
    Premiere CS3 needs a Core2Duo for most compressed formats. What is a "3000"?
    http://www.kiva.org/about
    than Q so much 4 response ,
    Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz (2 CPUs)
    Memory: 1016MB RAM
    the vid formats :
    - avi ( xvid ) & mpeg2
  4. Member edDV's Avatar
    Memory: 1016MB RAM
    the vid formats :
    That processor should handle MPeg2.
    xvid is not supported by CS3. You would need to decode it to uncompressed, MPeg2 or DV format.
    I've used both in PP CS4 before, and it should work fine. Do you have ffdshow installed? That is what is used by CS4 to decode Xvid/AVI files (it uses a directshow import). (enable xvid in the ffdshow configuration, set to libavcodec)
    What audio formats? Use mediainfo (view=>text)
  6. Member edDV's Avatar
    CS3/4 would not support xvid for preview window playback out of the box. It would look to Directshow.
    That doesn't mean xvid is supported as an import standard.
    I would also get more system memory, as PP CS4 eats a lot - it's a hog. 1GB is not enough. You can open up taskmanager and see how much is being used by your applications. Close down non-essential programs
    I would put your source files on a separate hard drive and free up space on your C: drive. 2.5GB free is tiny and it's probably fragmented. It is probably swapping to the page file with such low memory. This "thrashing" will greatly reduce performance. I would also defrag once you free up some space
    Sorry 4 retard and thank u so much ( poisondeathray & edDV ) 4 these very useful instructions
    - About the HDD , I increased the partition C: (8 GB free after installation ) & defragmented the entire HDD
    - About RAM , I ll increase it , because the problem is not solved yet. ... and I ll inform u about the result.
    - I face another problem ... I ll write it now in its section ... its in VDub ,it may be a part of this problem.
    CS3 works very slowly on a single-core machine,
    and CS4 won't even run.
    I only use CS3 on dual core with 2GB RAM,
    and CS4 only on dual or quad with at least 4GB RAM.
    8GB free? You need a much larger hard drive.
    Honestly, you need to convert the XVID pre-Premiere, using something like VirtualDub, to a lossless intermediary like HuffYUV or fully uncompressed YUY2. DirectShow decode in Premiere, for compressed formats, really sucks.
    For an older machine like that, you may need to consider finding Premiere 6.5 instead. It's far more stable on single-core systems, and more stable than some of the early Premiere "Pro CS" versions.
    • Premiere 6.0
      6.5
      7 = CS
      8 = CS2
      9 = CS3
      10 = CS4
    • Premiere 6.0
      6.5
      7 = CS
      8 = CS2
      9 = CS3
      10 = CS4
    Than Q so much 4 very good information
    - I ll upgrade my PC ... but I mean 8GB free after installation ... the whole partition is 15 GB ... The whole HDD is 640 GB ... Do u suggest increasing c: partition ? Core2duo & 3 GB RAM will perform well ?
    - May u help me in this problem ?
    http://forum.videohelp.com/topic375089.html
  1. Adobe Premiere Pro 2 Problem
    By mymuckaccount in forum Video Conversion
    Last Post: 20th May 2008, 16:17
  2. Adobe Premiere Pro 1.0 problem
    By The14thGOD in forum Computer
    Last Post: 26th Sep 2005, 09:22
  3. Replies: 4
    Last Post: 20th Jun 2003, 14:56
  4. problem with adobe premiere! Someone else?
    By javi-net in forum Editing
    Last Post: 22nd May 2002, 13:18
  5. another problem with adobe premiere 6.0...
    By glubu in forum Editing
    Last Post: 6th Jul 2001, 02:25
About   Advertise   Forum   RSS Feeds   Statistics   Tools
