VideoHelp.com Forum
    Hi,
    I previously used GOTSent to convert my MKV movies to MP4 and it worked great and fast, but unfortunately XBOX supports only 2 channels with this format.
    I found out that WMV-HD can be played on the XBOX with 5.1 channels so i used encode360 to convert and it went great, but... 2 questions -
    1. I have a pretty old PC, around 4 years old, and selecting the best quality conversion produced a file which is more than twice in size and took a day and a half to convert.
    Is there anything faster that can produce the same quality?
    2. The audio in the original file is DTS. Now my receiver recognizes PLII when i play the WMV-HD file through the XBOX360. Is that OK?
    Thanks in advance
    If your computer details are accurate, then you will be waiting for a long time with any WMV conversion, unless you drop the quality to an unacceptable level.
    You might want to consider converting to AVI (XviD) and converting the DTS to 5.1 AC3 audio, it should be faster to encode than WMV, and should be OK on the Xbox 360.
    XviD4PSP should be OK for this, but I have never tried it with DTS sources.
    Sorry, the details are not up to date.
    MB - MSI 945PL NEO-F 7.1 1GLAN
    Display adapter - MSI 7600GT
    Processor - PD820 2.8 2M DUALCORE
    2GB RAM
    See this link for XBOX360 support -
    http://support.xbox.com/support/en/u...aybackfaq.aspx
    The MKV sources i use are usually 720p, but if i convert MKV to avi, wouldn't i lose quality?
    The WMV-HD file i produces looks great, almost lossless i would say.
  4. Unregistered El Heggunte's Avatar
    WMV9 actually compresses worse (and slower ) than XviD for the same level of visual quality.
    A 720p XviD file would probably look just as good as the WMV version and XVID4PSP does have an AVI HD preset.
    Encode360 is a good encoder, but is limited in what settings you can change, what's missing in particular is Windows Media Encoder's -v_performance setting, which can drastically increase encoding speed, with very little quality loss.
  1. Replies: 7
    Last Post: 18th Jul 2010, 20:58
  2. Converting h.264 MKV to Play on PS3/Xbox360
    By Startropic1 in forum Video Conversion
    Last Post: 29th May 2009, 00:34
  3. mkv to xbox360 compliant .mp4
    By wallace4793 in forum Video Conversion
    Last Post: 26th Jun 2007, 14:13
  4. mkv to h264 xbox360?
    By Ducco in forum Video Conversion
    Last Post: 14th Jun 2007, 18:57
  5. Adding chapters to WMV file for use on Xbox360
    By brijazz in forum Video Conversion
    Last Post: 30th May 2007, 07:11
