I got the links easy with FireFox and rtmpdumphelper! I have added -v option, may it prevent from failing to download!
You should use newer rtmpdump! here!
Results 541 to 570 of 1207
Ok, I downloaded the newer version of the rtmpdump and the URLs that you provided worked. Thanks so much!!!!!
I then however tried to use RtmpHelper to do the next video:
http://www.dolce-sport.ro/sporturi/jocurile-olimpice/echipa-feminin-de-gimnastic-locul...aparate-14382/
I opened it in Firefox and here is what I got in the rtmpsuck:
http://screencast.com/t/ymoHeadyD
It however does not contain all the info you have in the command you gave me in your post. I am not sure what exactly I am doing wrong here,
Thanks a lot for your help! -
in rtmodumphelper --> options --> RTMPDump Option --> select "rtmp server" instead of "rtmp proxy server"! Then Try!
and I have removed un-needed parameters in command!! the command that it self creates is OK and full! There is no problem and you are not doing anything wrong! -
I was able to download the videos that I needed, but partially using Stream Support. The part that I could not get using RTMP tools was:
2012/08/07/mp4:izbasa-19_15_42_low.mp4
I tried what you suggested, I went into the options and selected RTMP server instead of the default option, but with that option selected, I only get this error:
ERROR: WriteN, RTMP send error xxxx (xx bytes)
ERROR: RTMP_ReadPacket, failed to read RTMP packet header
I am pretty sure I am missing something, but I do not see many options in the program...
Thanks! -
Can anyone help me download the video:
http://www.nbcolympics.com/video/soccer/united-states-vs-canada-womens-soccer-semifinal.html
URL snooper gives locations like the following: (the source ip seems to change)
http://ec.atdmt.com/ds/AAAVEBBUYB13/20120718Innovation2/B12_BTC_In_Fu_0713_A0_Stnds_BI...3/direct;wi.72
http://ec.atdmt.com/ds/AAAVEBBUYB13/20120718Innovation2/B12_BTC_In_Fu_0713_A0_Stnds_Im...hv2_728x90.swf
thank you very much -
With Coojah, track the packets until you find .m3u8 file and use it in ffmpeg as input! Then:
You can't use my script, because the link has expiration! you should get a new one for your self!Code:ffmpeg -i "http://www.youtube.com/api/manifest/hls_playlist/id/0f2523b412889 50c/itag/96/source/yt_live_broadcast/ratebypass/yes/cmbypass/yes/playlist_type/C LEAN/maudio/1/pmbypass/yes/upn/YJXU_CTb2vg/sver/3/ip/66.90.73.46/ipbits/8/expire /1344545894/sparams/ip,ipbits,expire,id,itag,source,ratebypass,cmbypass,playlist _type,maudio,pmbypass/signature/83591670F3417E19DB2C555F28DC5FFF75446D73.01F1AF2 F594890D478054573CDB670F57D30EC7F/key/ck1/file/index.m3u8" "olympic.mp4" ffmpeg version N-43206-gf857465 Copyright (c) 2000-2012 the FFmpeg developers built on Aug 4 2012 16:10:39 with gcc 4.7.1 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass --enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable -libfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libope njpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libth eora --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable- libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --e nable-zlib libavutil 51. 66.100 / 51. 66.100 libavcodec 54. 49.100 / 54. 49.100 libavformat 54. 22.100 / 54. 22.100 libavdevice 54. 2.100 / 54. 2.100 libavfilter 3. 5.102 / 3. 5.102 libswscale 2. 1.100 / 2. 1.100 libswresample 0. 15.100 / 0. 15.100 libpostproc 52. 0.100 / 52. 0.100 [mpegts @ 02638260] Estimating duration from bitrate, this may be inaccurate Input #0, hls,applehttp, from 'http://www.youtube.com/api/manifest/hls_playlist/ id/0f2523b41288950c/itag/96/source/yt_live_broadcast/ratebypass/yes/cmbypass/yes /playlist_type/CLEAN/maudio/1/pmbypass/yes/upn/YJXU_CTb2vg/sver/3/ip/66.90.73.46 /ipbits/8/expire/1344545894/sparams/ip,ipbits,expire,id,itag,source,ratebypass,c mbypass,playlist_type,maudio,pmbypass/signature/83591670F3417E19DB2C555F28DC5FFF 75446D73.01F1AF2F594890D478054573CDB670F57D30EC7F/key/ck1/file/index.m3u8': Duration: 02:33:46.00, start: 42130.197067, bitrate: 0 kb/s Stream #0:0: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1: Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, stereo, s16, 159 kb/s [libx264 @ 03cf0940] using SAR=1/1 [libx264 @ 03cf0940] using cpu capabilities: MMX2 SSE2 SSE3 Cache64 [libx264 @ 03cf0940] profile High, level 3.1 [libx264 @ 03cf0940] 264 - core 125 r2208 d9d2288 - H.264/MPEG-4 AVC codec - Cop yleft 2003-2012 - http://www.videolan.org/x264.html - options: cabac=1 ref=3 deb lock=1:0:0 analyse=0x3:0x113 me=hex subme=7 psy=1 psy_rd=1.00:0.00 mixed_ref=1 m e_range=16 chroma_me=1 trellis=1 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chro ma_qp_offset=-2 threads=1 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 i nterlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=2 keyint=250 keyint_min=25 scenec ut=40 intra_refresh=0 rc_lookahead=40 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin= 0 qpmax=69 qpstep=4 ip_ratio=1.40 aq=1:1.00 Output #0, mp4, to 'olypic.mp4': Metadata: encoder : Lavf54.22.100 Stream #0:0: Video: h264 ([33][0][0][0] / 0x0021), yuv420p, 1920x1080 [SAR 1: 1 DAR 16:9], q=-1--1, 25 tbn, 25 tbc Stream #0:1: Audio: aac ([64][0][0][0] / 0x0040), 48000 Hz, stereo, s16, 128 kb/s Stream mapping: Stream #0:0 -> #0:0 (h264 -> libx264) Stream #0:1 -> #0:1 (aac -> libvo_aacenc) Press [q] to stop, [?] for help frame= 22 fps=0.0 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 24 fps= 18 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 25 fps=5.8 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 26 fps=3.6 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 26 fps=2.4 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 28 fps=2.0 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 29 fps=1.5 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 29 fps=1.3 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 29 fps=1.2 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 31 fps=1.2 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 32 fps=1.2 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 32 fps=1.1 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 32 fps=1.1 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 34 fps=1.1 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 35 fps=0.9 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 36 fps=0.9 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 36 fps=0.9 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 38 fps=0.8 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 38 fps=0.8 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 40 fps=0.8 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 41 fps=0.8 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 41 fps=0.7 q=0.0 size= 0kB time=00:00:00.00 bitrate= 0.0kbits/s frame= 43 fps=0.7 q=28.0 size= 34kB time=00:00:00.00 bitrate= 0.0kbits/ frame= 44 fps=0.7 q=28.0 size= 42kB time=00:00:00.04 bitrate=8502.2kbits/ frame= 44 fps=0.7 q=28.0 size= 42kB time=00:00:00.04 bitrate=8502.2kbits/ frame= 46 fps=0.7 q=28.0 size= 59kB time=00:00:00.12 bitrate=4041.1kbits/ frame= 47 fps=0.7 q=28.0 size= 70kB time=00:00:00.16 bitrate=3562.7kbits/ frame= 47 fps=0.7 q=28.0 size= 70kB time=00:00:00.16 bitrate=3562.7kbits/ frame= 49 fps=0.7 q=28.0 size= 88kB time=00:00:00.24 bitrate=2999.1kbits/ frame= 50 fps=0.7 q=28.0 size= 97kB time=00:00:00.28 bitrate=2833.3kbits/ frame= 50 fps=0.7 q=28.0 size= 97kB time=00:00:00.28 bitrate=2833.3kbits/ frame= 52 fps=0.7 q=28.0 size= 116kB time=00:00:00.36 bitrate=2645.8kbits/ frame= 53 fps=0.7 q=28.0 size= 126kB time=00:00:00.40 bitrate=2572.0kbits/ frame= 54 fps=0.7 q=28.0 size= 135kB time=00:00:00.44 bitrate=2508.5kbits/ frame= 54 fps=0.7 q=28.0 size= 135kB time=00:00:00.44 bitrate=2508.5kbits/ frame= 56 fps=0.7 q=28.0 size= 153kB time=00:00:00.52 bitrate=2413.8kbits/ frame= 57 fps=0.7 q=28.0 size= 162kB time=00:00:00.56 bitrate=2375.7kbits/ frame= 57 fps=0.6 q=28.0 size= 162kB time=00:00:00.56 bitrate=2375.7kbits/ frame= 57 fps=0.6 q=28.0 size= 162kB time=00:00:00.56 bitrate=2375.7kbits/ frame= 59 fps=0.6 q=28.0 size= 181kB time=00:00:00.64 bitrate=2320.6kbits/ frame= 60 fps=0.6 q=28.0 size= 189kB time=00:00:00.68 bitrate=2282.2kbits/ frame= 61 fps=0.6 q=28.0 size= 200kB time=00:00:00.72 bitrate=2278.3kbits/ frame= 61 fps=0.6 q=28.0 size= 200kB time=00:00:00.72 bitrate=2278.3kbits/ s dup=1 drop=0
Thank you very much Bahman.
I was also able to find the *.m3u8 file using Firefox: Tools -> Web Developer -> Web Console; Filter: m3u8
These files are large and often the download is interrupted before the end of the file.
Could I use the -ss option to break these downloads up into segments?
Is there a way to resume an interrupted download?
thanks again. -
I wonder if they are screwing that coverage up as wretchedly as they are mishandling their U.S. broadcasting ?
http://forum.videohelp.com/threads/348304-Olympics-Coverage-Question-Comment?p=2179185#post2179185When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- over 150 tables from 6+ decades of this gradually disappearing American art form. -
Can anyone check something for me? I've tried to get the following using rtmpdump or the nirsoft RTMPDumpHelper, but I just can't make any magic happen. I'm using the latest 2.4 linked above with no success:
http://tvnz.co.nz/animal-academy/s5-ep10-video-4876127 -
Well, It's a rtmpe stream! You have to use rtmpdump then! Open rtmpdumphelper and go to options and use rtmp server (rtmpsrv) instead of rtmpsuck! It should detects the link and tries to download that! if there is a problem, your firewall or sth is making noises! lol
hrmm...still perplexed....I must be missing something obvious. When I run the RTMPDumpHelper, it attaches to the browser it launches the rtmpsrv, i go to the page with the video and RTMPDumpHelper says "Captured RTMP Connection", but it never saves anything to file and the command window for rtmpsrv doesn't show any activity.
Firewall is disabled. Running on Windows7 and have tried running everything with full admin priveleges and no success....
I've tried other videos listed here in this thread and I can't get them to download either...
I'm stumped... -
^Try StreamTransport 1.0.2.2041!! Do not download latest version! May it helps!
Hi!
I have a problem downloading a video from Moshcam: http://www.moshcam.com/the-jezabels/enmore-theatre-933.aspx
I used this code:
and this one:Code:rtmpdump -r "rtmpe://streaming.moshcam.com" -a "" -f "LNX 10,1,102,65" -W "http://www.moshcam.com/chooktv/Core/Flash/Container.swf" -p "http://www.moshcam.com/the-jezabels/enmore-theatre-933.aspx" -y "mp4:jezabels_003_20111021_e_hd_moshcam_1692k_480p.mp4" -o jezabels_003_20111021_e_hd_moshcam_1692k_480p.flv
Neither works. I received a message like:Code:rtmpdump -r "rtmpe://cp163278.edgefcs.net" -f "LNX 10,1,102,65" -W "http://www.moshcam.com/chooktv/modules/Container.swf" -p "http://www.moshcam.com/the-jezabels/enmore-theatre-933.aspx" -y "1692k/jezabels_003_20111021_e_hd_moshcam_1692k_480p.mp4" -o jezabels_003_20111021_e_hd_moshcam_1692k_480p.flv
Anyone could fix the errors on these command lines?RTMPDump v2.4 GIT-2011-07-11 (Compiled by KSV)
(c) 2010 Andrej Stepanchuk, Howard Chu, The Flvstreamer Team; license: GPL
WARNING: No application or playpath in URL!
Connecting ...
WARNING: HandShake: Type mismatch: client sent 6, server answered 9
INFO: Connected...
ERROR: rtmp server sent error
ERROR: rtmp server requested close
Thanks.
PS: I used rtmpdump 2.4 -
rtmpdump -r "rtmpe://cp163278.edgefcs.net/ondemand/" -a "ondemand/" -W "http://www.moshcam.com/chooktv/modules/Container.swf" -y "mp4:videos-moshcam/moshcam/1692k/jezabels_003_20111021_e_hd_moshcam_1692k_480p.mp4" -o jezabels_003_20111021_e_hd_moshcam_1692k_480p.flv
Code:RTMPDump v2.4 (c) 2010 Andrej Stepanchuk, Howard Chu, The Flvstreamer Team; license: GPL Connecting ... WARNING: HandShake: Type mismatch: client sent 6, server answered 9 INFO: Connected... Starting download at: 0.000 kB INFO: Metadata: INFO: duration 4233.09 INFO: moovPosition 36.00 INFO: audiocodecid mp4a INFO: width 854.00 INFO: height 480.00 INFO: videocodecid avc1 INFO: avcprofile 100.00 INFO: avclevel 31.00 INFO: aacaot 2.00 INFO: audiosamplerate 44100.00 INFO: audiochannels 2.00 INFO: videoframerate 25.00 INFO: tags: INFO: cpil 0.00 INFO: tmpo 0.00 INFO: ©too Sorenson Squeeze INFO: trackinfo: INFO: length 186679296.00 INFO: timescale 44100.00 INFO: language und INFO: sampledescription: INFO: sampletype mp4a INFO: length 2539855.00 INFO: timescale 600.00 INFO: language und INFO: sampledescription: INFO: sampletype avc1 INFO: length 2539855.00 INFO: timescale 600.00 INFO: language und INFO: sampledescription: INFO: length 2539855.00 INFO: timescale 600.00 INFO: language und INFO: sampledescription: 260.396 kB / 1.96 sec (0.0%)
Bahman how long should i wait till it finishes ? furthermore i copied the incomplete mp4 while in process to different folder and tried to play it with VLC Media player but it didnot play the video it closed the player!! could you tell me why ? should i wait till it finishes ?
thanks bahman . is there away to know the final file size while the process is not finished ?for one hour video the process takes one hour to complete or it depends to my internet speed?
It depends on your internet speed! you can estimate the file size! for example if an event is 3h, see how many the size of 30min is, then x6 of that size is the final size!
Bahman how we can specify what bitrate we want ? furthermore i should use :
at the end of process to convert it to .mkv?Code:ffmpeg -i whatever.m3u8 -c copy olympics.mkv
Is it possible to get segments of video instead of the whole video at once ?Last edited by spiderMan007; 15th Aug 2012 at 13:35.
Hey , can you help me to download this : http://www.youtube.com/watch?v=XhVpzKVuRQ8&feature=watch-now-button&wide=1
I tried with Get FLV , Stream Transport and RTMPExplorer ( with the last one i m not very good ) but can`t downloade the video , can you tell how can i do or another program ? please -
They seem to have this 'Sign In' BS going on now for some videos, but that likely isn't part of the problem you are encountering. Since when did YT start having any videos longer than about 10 minutes ? This seems to be ALL of a 1hr. 37 min. movie, and not broken up into segments, either. I guess I haven't been paying much attention to what's going on at YT.
A few things I tried -- quickly -- didn't worth either, but I didn't get to Coojah / Blader.
I thought the sole justification for buying Get FLV at their exorbitant price was that it supposedly could get everything ?When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- over 150 tables from 6+ decades of this gradually disappearing American art form. -
How to download a rtmp stream from a website
By krb214 in forum Video StreamingReplies: 2Last Post: 26th Jul 2011, 18:08 -
Need some advice on how to download certain rtmp streams
By aveceux in forum Video StreamingReplies: 3Last Post: 13th Jun 2011, 08:45 -
Free DivX Pro Software Download
By MJA in forum Video ConversionReplies: 11Last Post: 18th Dec 2010, 07:21 -
RTMP Flash file help?
By xiaofan in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2007, 08:16
