Thanks a lot, Bahman, I'm working on them now, quick questions:^You are welcome!
Yeah, why not!!Im trying to download a couple of videos from MTV such as:
http://www.mtv.com/videos/true-life-...playlist.jhtml
Can someone help me?
True Life | I'm Getting A Second Chance
Code:rtmpdump -r "rtmpe://cp10740.edgefcs.net/ondemand/" -a "ondemand/" -W "http://media.mtvnservices.com/player/prime/mediaplayerprime.1.12.1.swf" -y "mp4:mtvnorigin/gsp.originmusicstor/sites/mtv.com/shows/true_life/mt_tl_rt274077_s1_1280x720_3500_h32.mp4" -o mt_tl_rt274077_s1.flvCode:rtmpdump -r "rtmpe://viacommtvstrmfs.fplive.net/viacommtvstrm/" -a "viacommtvstrm/" -W "http://media.mtvnservices.com/player/prime/mediaplayerprime.1.12.1.swf" -y "mp4:gsp.originmusicstor/sites/mtv.com/shows/true_life/mt_tl_rt274077_s2_1280x720_3500_h32.mp4" -o mt_tl_rt274077_s2.flvCode:rtmpdump -r "rtmpe://viacommtvstrmfs.fplive.net/viacommtvstrm/" -a "viacommtvstrm/" -W "http://media.mtvnservices.com/player/prime/mediaplayerprime.1.12.1.swf" -y "mp4:gsp.originmusicstor/sites/mtv.com/shows/true_life/mt_tl_rt274077_s3_1280x720_3500_h32.mp4" -o mt_tl_rt274077_s3.flvCode:rtmpdump -r "rtmpe://viacommtvstrmfs.fplive.net/viacommtvstrm/" -a "viacommtvstrm/" -W "http://media.mtvnservices.com/player/prime/mediaplayerprime.1.12.1.swf" -y "mp4:gsp.originmusicstor/sites/mtv.com/shows/true_life/mt_tl_rt274077_s4_1280x720_3500_h32.mp4" -o mt_tl_rt274077_s4.flvCode:rtmpdump -r "rtmpe://viacommtvstrmfs.fplive.net/viacommtvstrm/" -a "viacommtvstrm/" -W "http://media.mtvnservices.com/player/prime/mediaplayerprime.1.12.1.swf" -y "mp4:gsp.originmusicstor/sites/mtv.com/shows/true_life/mt_tl_rt274077_s5_1280x720_3500_h32.mp4" -o mt_tl_rt274077_s5.flvCode:rtmpdump -r "rtmpe://viacommtvstrmfs.fplive.net/viacommtvstrm/" -a "viacommtvstrm/" -W "http://media.mtvnservices.com/player/prime/mediaplayerprime.1.12.1.swf" -y "mp4:gsp.originmusicstor/sites/mtv.com/shows/true_life/mt_tl_rt274077_s6_1280x720_3500_h32.mp4" -o mt_tl_rt274077_s6.flv
True Life | I Have A Fetish
Code:rtmpdump -r "rtmpe://viacommtvstrmfs.fplive.net/viacommtvstrm/" -a "viacommtvstrm/" -W "http://media.mtvnservices.com/player/prime/mediaplayerprime.1.12.1.swf" -y "mp4:gsp.originmusicstor/sites/mtv.com/shows/true_life/mt_tl_fetish_rt240772_s1_1280x720_3500_h32.mp4" -o mt_tl_fetish_rt240772_s1.flvCode:rtmpdump -r "rtmpe://viacommtvstrmfs.fplive.net/viacommtvstrm/" -a "viacommtvstrm/" -W "http://media.mtvnservices.com/player/prime/mediaplayerprime.1.12.1.swf" -y "mp4:gsp.originmusicstor/sites/mtv.com/shows/true_life/mt_tl_fetish_rt240772_s2_1280x720_3500_h32.mp4" -o mt_tl_fetish_rt240772_s2.flvCode:rtmpdump -r "rtmpe://viacommtvstrmfs.fplive.net/viacommtvstrm/" -a "viacommtvstrm/" -W "http://media.mtvnservices.com/player/prime/mediaplayerprime.1.12.1.swf" -y "mp4:gsp.originmusicstor/sites/mtv.com/shows/true_life/mt_tl_fetish_rt240772_s3_1280x720_3500_h32.mp4" -o mt_tl_fetish_rt240772_s3.flvCode:rtmpdump -r "rtmpe://viacommtvstrmfs.fplive.net/viacommtvstrm/" -a "viacommtvstrm/" -W "http://media.mtvnservices.com/player/prime/mediaplayerprime.1.12.1.swf" -y "mp4:gsp.originmusicstor/sites/mtv.com/shows/true_life/mt_tl_fetish_rt240772_s4_1280x720_3500_h32.mp4" -o mt_tl_fetish_rt240772_s4.flvCode:rtmpdump -r "rtmpe://cp10740.edgefcs.net/ondemand" -a "ondemand/" -W "http://media.mtvnservices.com/player/prime/mediaplayerprime.1.12.1.swf" -y "mp4:mtvnorigin/gsp.originmusicstor/sites/mtv.com/shows/true_life/mt_tl_fetish_rt240772_s5_1280x720_3500_h32.mp4" -o mt_tl_fetish_rt240772_s5.flvUse rtmpdump v2.5, Good Luck!!Code:rtmpdump -r "rtmpe://cp10740.edgefcs.net/ondemand" -a "ondemand/" -W "http://media.mtvnservices.com/player/prime/mediaplayerprime.1.12.1.swf" -y "mp4:mtvnorigin/gsp.originmusicstor/sites/mtv.com/shows/true_life/mt_tl_fetish_rt240772_s6_1280x720_3500_h32.mp4" -o mt_tl_fetish_rt240772_s6.flv
1. Why are the links segmented?
2. What method did you use to get the links?
Thank you once again![]()
Results 481 to 510 of 1107
^1. There is no difference between this method and one long link! just in this method, you can understand what are app path and play path!!
2. Manual Way!! btw, also you need a USA proxy/vpn to do this method!! -
I am able to download it using DownloadHelper, but the video only loads via an Australian proxy, and what is downloaded is very low-res. Is there anyway that I can download the videos with the highest quality video setting (1,500k)?
Hi all,
I used RTMP explorer to capture the video at -
http://www.moshcam.com/clutch-pt-1-b...2.aspx#/1-1906
But when I try to play the saved .flv file (with VLC) it tells me that "VLC does not support the audio or video format "undf". Unfortunately there is no way for you to fix this."
Am I doing something wrong? I have successfully saved other videos from Mosh Cam.
Thanks!
I downloaded the streamtransport here and it worked without problems in VLC.
You may need to update the codecs on your PC.
Hi all, I used rtmpgw for my enigma2 receiver but I didnt play this :
http://www.showtvnet.com/player/inde...roduct=showtv1
with rtmpdump playing well but if I stoped and than start again stream is not working, this parameters always change:
showtv1?0c263cde983e2134c1ad8f64b1539be7bc9892e9d0 59d4e706ccb94a18fbc02453e4
and sory for my bad english. thanks.. -
hi guys, I came across this site and used the rtmpExplorer to capture streaming flash videos from Digital Tutors webpage, it was working great then around half way through the video set (30 Videos in Total), the format stoped converting and is now only downloading the .flv format which wont play. To begin with working videos worked with WMP,Real Player etc but once it stopped working no player will open the files, the error 'undf'.
just to add, IE is up to date as well as Java, Flash Player is there anything ells I need to update/need maybe? -
EDIT: Nevermind, I ended up using rtmp-host.sh and everything went wonderfully.
Hello , i need to download Video from this URL:
rtmpe://vod.sk.prg.cmestatic.com/voyosk/mp4:2011/09/11/2011-09-11_11SEPTEMBER-1.mp4
,but rtmp gives me error : .... Server not genuine Adobe!Last edited by obykoo; 11th Jun 2012 at 12:49.
Can any one try to download the below video and please let me know the process how to download.
http://www.youtube.com/watch?v=-iC8MQvd-e4&hd=1Last edited by sreekant; 13th Jun 2012 at 07:51.
Hey all
As an individual affected by MS, I am desperately trying to capture this CBC stream "MS Wars" for offline viewing. I have attempted using rtmpdump, and am having no luck at all.
http://www.cbc.ca/natureofthings/epi...internet.html#
Any assistance would be greatly appreciated.
Cheers,
J -
Results with Orbit + FF-12 were negative (just showing some small .SWF files, which is useless); YTF script also negative. [Netflix says "Download Links Not Available."] Haven't tried other options, yet.
When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- over 150 tables from 6+ decades of this gradually disappearing American art form. -
fill highlighted sections in your command:
rtmpdump -r "rtmpe://vod.sk.prg.cmestatic.com/voyosk/" -a "voyosk/" -W "flash player path.swf" -p "website address" -y "mp4:2011/09/11/2011-09-11_11SEPTEMBER-1.mp4" -o "output.flv"
Then, you can dl your vid!
The first and the last option for youtube's rtmpe streams is GetFLV!!
Hi Bahman,
I have question about Whiteshark. I used Whiteshark to sniff rtmp link and the auth link for ITV. I tried the same method for 4oD and Demand 5 but no luck. Could you show me how this could be done for those both channels?. I used rtmpexplorer but it only download video with low bitrate and I used Whiteshark to get highest bitrate.Last edited by ka6_jeram; 17th Jun 2012 at 14:08.
hey,
at the moment I'm trying to get some of the arte streams of the hellfest festival but it doesn't seem to work.
For example the lockup show located on http://liveweb.arte.tv/de/video/Hellfest_Lock_Up/.
URL snooper shows me the rtmpt://arte.fcod.llnwd.net/a2306/o25 and rtmp://arte.fcod.llnwd.net:1935/a2306
and when I download the rtmpt it downloads a 0kb .flv file and when I use the rtmp it downloads nothing.
it shows the error: "you must specify a playpath.........."
but if the playpath isn't "a2306" what else could it be?
Any help would be appreciated. Thanks a lotLast edited by Gwar; 24th Jun 2012 at 15:08.
Download this package and extract it into one folder, then open rtmpexplorer. will be opened 2 windows(rtmpexplorer+rtmpsrv)!! close rtmpsrv and open rtmpsuck! put the webpage link in rtmpexplorer, then you will see rtmpsuck detects the stream url and tries to download that!!
thanks a lot, that worked really well.
The only problem I have now it that it doesn't download the complete show. the show was 45:12 minutes and it quit after 34:48. There is an error message at the end saying: ERROR: RTMP_ReadPacket, failed to read RTMP packet header
ERROR: Request timeout/select failed, ignoring request.
Closing connection... done!
thanks for your help -
it worked after I tried it again. thanks, this tool rules and is easy to use.
By the way is the .mp4 the format which was used on the site or does the rtmp sucker convert all streams into .mp4? -
Hi, I subscribe to a couple of streaming movie sites, but sometimes it is more convenient for me to download a movie to my laptop and watch it later, for example when I am on the road and the hotel I am at either has no free wi-fi, or no wi-fi at all. After doing a lot of Googling I tried the trial version of Replay Capture Suite. The trial version limits you to recrording just 2 minutes of a stream, but it worked perfectly on the test movie I chose. So I bought the full product, $79. HOWEVER, the full version refuses to record the stream, (of that same movie) or any other stream from that site (and a number of other pay video sites), as it generates a pop-up that says that it might be infringing copyright, and so refuses to record. It goes on to say that the only way to 'legally' record the movie is to use another product in the suite, a screen recorder, that produces much lower resolution copies, full of stop/starts and stuttering throughout.
I also tried two freeware products, Tubedigger and StreamTransport, but they require you to enter the URL of the movie site in their own GUI, and when I log in to my subscription sites, and try to select the movie to watch, it fails, with a 'Script error on page' (Expected identifier, string or number) dialog in both products, the embedded flash player never appears (just a blank space, with 'You need Adobe Flash installed' above it). Logging in via any browser (IE, FF, Chrome) does not produce any script errors, and the embedded flash player appears no problem.
I then downloaded the RTMPExplorer package, and URLSnooper. URLSnooper reported a *.swf file URL whenever I opened a movie to watch, and an rtmpe file url. The files were of the form:
h t t p://abcde4567.somesite.com/member/ninja/player/4feb3b5808bd54feb3b5808c0e_4feb3b5808bd5.swf
and
rtmpe://somesite.com/moviegenre
I opened RTMPExplorer, closed rtmpsvr and opened rtmpsuck, then pasted the *.swf url into RTMPExplorer and prayed. No luck, nothing happened.
Anyone any ideas what to try next?
UnderlordLast edited by Underlord; 29th Jun 2012 at 15:10.
Hi I was trying to download the Euro 2012 final from tsn's site located here
http://www.tsn.ca/window/euro2012/
(click on EURO VOD: Final - Spain vs. Italy at the bottom)
I am able to get the first half, but the 2nd half unable to with rtmpexplorer. Anyone able to help out?
Thanks -
I am using RTMPExplorer and was wondering if it is necessary to watch the whole video in order for the video to be downloaded? If so, is there a way to just have the video download in the background so that I can start on downloading a different video?
hai i still cant download from this site site already remove
i try using RTMPEXplorer but still cant detect RTMP
Please help me..Last edited by ahm2480; 22nd Jul 2012 at 23:18.
Their site doesn't use RTMP streaming, they are using Adobe HTTP Dynamic Streaming!
You have to use AdobeHDS's PHP script!
How to download a rtmp stream from a website
By krb214 in forum Video StreamingReplies: 2Last Post: 26th Jul 2011, 18:08 -
Need some advice on how to download certain rtmp streams
By aveceux in forum Video StreamingReplies: 3Last Post: 13th Jun 2011, 08:45 -
Free DivX Pro Software Download
By MJA in forum Video ConversionReplies: 11Last Post: 18th Dec 2010, 07:21 -
RTMP Flash file help?
By xiaofan in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2007, 08:16
. Yup, wireshark.
