I've been converting almost any kind of video into avi format and recently i have notice that some part of the video has different bitrate .For example ,to minimize wast of file size i use MEDIA INFO software to determine how much bitrate is it to convert into another format like avi but then again some part or the movie has more bit rate than it show on the software so in result that part of the video quality dramatically reduce .To prevent that i have to convert a whole video with ridiculously amount of bitrate .I'm using any video converter software free version and there is no auto bit rate detecting system so how should i fix it without wasting file size and video quality.
Use constant quality encoding. You get exactly the right bitrate at each and every frame to deliver the quality you specify.
It makes no sense to use the same bitrate as your source unless you are using the same codec and the same settings. In which case there's no reason to be doing the conversion.
Reducing the size of an avi file with Vegas 9.0
By solarblast in forum Video ConversionReplies: 10Last Post: 3rd Sep 2011, 22:01 -
Reducing video file size
By black5 in forum Newbie / General discussionsReplies: 2Last Post: 15th Jul 2010, 17:09 -
Limitingand reducing out file size
By TJF in forum Video ConversionReplies: 6Last Post: 7th Feb 2010, 09:25 -
reducing video file size
By srckaimal in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jan 2008, 20:51 -
Reducing mpg file size
By sknox in forum MacReplies: 2Last Post: 3rd Jul 2007, 04:41
Statistics
Newest guides
Latest tool updates
New media comments
