Does this program re-encode all inputs or just ones that are not compliant? I looked at it and the encoder doesn't have a lot of options unless I'm not looking at it right. I thought I would edit, encode and then use this for my menus and final VOB.
If you load an mpg file into the program, on the SOURCE screen click on the SETTINGS button, then click on the VIDEO button. There you can choose whether to re-encode the mpg file or use smart rendering. Same applies to the audio.
Brainiac
Smart rendering I assume leaves it alone and will only encode the menu's and stuff?
TMPGEnc Authoring Works 4
By mdw46 in forum Authoring (DVD)Replies: 2Last Post: 29th Nov 2009, 16:18 -
Tmpgenc Authoring works
By quxote in forum Authoring (DVD)Replies: 1Last Post: 27th Nov 2009, 16:56 -
By Ldwlh in forum Authoring (DVD)Replies: 1Last Post: 18th Aug 2009, 18:00 -
Tmpgenc authoring works
By hamilton accie in forum Authoring (DVD)Replies: 2Last Post: 29th Jul 2009, 09:32 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 22:15
Statistics
Newest guides
Latest tool updates
New media comments
