I’m looking for some flexible and easy to use software to create DVD slideshows.
I need to be able to order photos in date/time sequence according to the EXIF data from multiple sources
e.g
2 Digital cameras and a phone camera, all on 1 slideshow with photos ordered by date/time taken.
Ability to add audio and customise the slideshow would be nice.
So far I’ve tried
Magix Photos on CD&DVD Deluxe 2.0, Nero 6, Pro Show Gold, Windows Live Movie Maker.
I’d be grateful for any recommendations
Results 1 to 10 of 10
Thread: EXIF capable slideshow editor
Adobe Lightroom 2
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Many thanks the for the suggestion and quick reply!
I'll give the trial a go, however is there anything out there without the huge price tag as this is for home use (family holiday snaps) and I figure Lightroom is overkill for this - unless there's not many other programs with exif support?
Picasa 3
DVD slideshow GUI (freeware) can use EXIF data(from jpg) as subtitles. Subtitles can automatically be sorted in alphabetic order. Afterwards can the subtitles be deleted or swiched off.
Sorting and ordering > AmoK Exif Sorter 2.54
Thanks again for the suggestions - I've tried them out with the following results:
Can't work out how to order the images in video maker by exif time/dateOriginally Posted by BogieV
When importing a folder of photos (slides) for a slideshow, unfortunatley the program stops responding when it reaches about the 10th image.Originally Posted by tin2tin
If you're importing heavy images then wait(the interface may look idle - but give it a change to fiinsh) or downsize your images.
Ok thanks, looks like waiting for the program to add the files (during 'not responding') works.Originally Posted by tin2tin
There are 3 sets of photos in the slideshow, from 3 different cameras.
I would like the slideshow to show the photos in sequence of when they were taken, regardless of which camera they came from.
This is where I was hoping the EXIF data would come in. Each file has valid EXIF date and time data - can you explain how the subtitle feature can pick up on this to order the photos correctly.
I don't want to have to edit properites of each individual photo, as there are nearly 1000 in the collection.
Many thanks
Okay, there are two ways to get EXIF data imported into DSG.
One is in the Project Settings menu > Import Settings/Subtitles > Photo Data where you can select what EXIF data should be imported as subtitle.
And the other one is to select in DSG the photos you want to add EXIF data to and in Slide Settings menu change the Photo Data combobox to what you want to be added.
Then select Edit > Sort Subtitles and they will be sorted alphabetic.
Rendering a slideshow out of 1000 photos will demand a lot of RAM and a fast computer... You might try to learn how to use DSG with a few slides first.I don't want to have to edit properites of each individual photo, as there are nearly 1000 in the collection.
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 4Last Post: 2nd Apr 2012, 01:28 -
Adjust AVCHD mts file EXIF date-time
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2011, 23:56 -
DVD slideshow GUI - problem with subtitles imported from exif
By jaceko in forum ProgrammingReplies: 10Last Post: 19th Jul 2009, 22:00 -
Is this remote capable?
By random0xff in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Feb 2008, 09:23 -
Overlaying EXIF data onto video
By fredfillis in forum Newbie / General discussionsReplies: 6Last Post: 12th Jul 2007, 04:37
