VideoHelp.com Forum
  1. I have an old Epson Scanner and I want to scan in a book in the 300dpi image format. I scanned a page and saved as jpg but the file was too big (700kb) and rotated. Then I saved as pdf, and the file size was much more reasonable (120kb), however, the 2 pages are rotated. I tried different settings in the scan (like portrait, landscape) but the page is still rotated. I can use the Acrobat viewer and hand rotate to the correct orientation, but I have to rotate each page and cannot save the rotated page. I am wondering if there is some software that will solve this problem, ie allow me to bulk rotate and bulk save all the pages in the pdf format. Ideally, I would like to just save the whole book as 1 pdf file (instead of a file for each page).
  2. did you scan every other page upside down? or scan both pages at once? most people scan one page at a time as adobe handles that just fine.
  3. I just lay the book on the scanner and scan the 2 pages at a time. I don't want to waste my time to scan each page.
    I want the 2 pages to appear in the correct orientation.
  4. PROBLEM SOLVED
    I downloaded free software called
    PDFill FREE PDF Tools 7.0
    http://www.freedownloadscenter.com/B...PDF_Tools.html
    and first merged all the scans and then rotated. (See screenshot)
    At the bottom of this post is a link (rot.pdf) that shows 25 pages scanned, merged and rotated for easy reading using the above software.
    rot.pdf
    The reason your PDF files are so much smaller than the JPG files is because they are saved in two color mode (black/white). This has ruined all the pictures and given you really ragged text.
  6. Ah yes. I tried to scan a page at 8-bit grayscale pdf, (see screenshot) but the amount of time to scan one page was about 3 times longer than black & white. File size about 600kb. The pictures were much better though. Scanning the whole book would take over 2 hours, versus the 45 minutes for black & white. Not worth it. I just want to have a basic back up copy to store online.
    Question: I am curious, do newer scanners take less time to scan (and get good picture rendering)?
  7. If it's a common book it may already by scanned by someone & on the net.
    I did my last book -- a very rare and expensive one, just in case -- using Abbyy Pro. I OCR's all the text to Word, and made a true PDF from it. Images scanned separately in Photoshop, re-inserted where needed. Not a lot of photos in this book.
  1. Computer-to-TV question...
    By Senex in forum Computer
    Last Post: 13th Nov 2010, 17:32
  2. Replies: 1
    Last Post: 9th Dec 2009, 23:33
  3. Question about pdf book scan that can be edited
    By jimdagys in forum Computer
    Last Post: 3rd Nov 2009, 02:27
  4. Question about possible adware on my computer
    By jimdagys in forum Newbie / General discussions
    Last Post: 16th Apr 2009, 07:16
  5. Replies: 2
    Last Post: 30th May 2007, 19:09
