Ok .. so we have a DVD that we are authoring and would like to put a "Play on your PC" type feature on it as well (basically just a .wmv file).
Can I just add the additional "bonus" content to the disc layout before burning the image?
with the file structure looking like this.
Disc->
VIDEO_TS ->
| .VOBs and what not
AUDIO_TS->
| EMPTY
Bonus ->
| bonusfeaturette.wmv
is that the way to do it?
also .. how would i go about auto playing the wmv file when the disc is inserted into the PC.
Thanks in advance,
-C
Just put the wmv in unused space and create a txt file to explain it.
The DVD standard dosen't include "extras".
A Phillips 5990/5992 will see it in the root directory if you use the USB menu.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Cool .. I'll give it shot, I wonder if adding an autorun.exe would make it play the wmv file automatically ... hmmmm
Not supported by any standard. You could write an application to do that.Originally Posted by pendalRecommends: Kiva.org - Loans that change lives.
That will not work if the end-user has been wise enough to disable AutoRun.also .. how would i go about auto playing the wmv file when the disc is inserted into the PC.
Quite right. And for security reasons I would suggest that everyone disable AutoRun. By the way, AutoRun won't work on Linux or Mac, so your bonus file won't automatically start on those operating systems.Originally Posted by El Heggunte
WebEx WMV file, can't open in VirtualDub, says "missing codec"
By violetta in forum Newbie / General discussionsReplies: 11Last Post: 22nd Mar 2010, 15:37 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 18:40 -
"The Godfather" Bonus Disc Problem
By the goddammitfather in forum Newbie / General discussionsReplies: 2Last Post: 27th Dec 2006, 12:03 -
"Bonus" footage in Sin City
By 8ju4gr3nml in forum Newbie / General discussionsReplies: 0Last Post: 23rd Aug 2005, 06:21 -
Adding "bonus" music to a DVD
By RNTS in forum AudioReplies: 1Last Post: 20th May 2004, 01:18
