VideoHelp.com Forum
Results 1 to 15 of 15
    y dose directshows always deinterlace my h.264 tv rips when i watch in mediaplayer classic or make a avs script please how do i turn it off i have checked settings and its not slected to deinterlace but it allways dose help
    are your rips interlaced?
    what decoder are you using ? did you check the settings?
    what happens in another player eg. vlc or kmplayer?
    playing them in vlc player there interlaced and mediplayer classic there not because it uses directshows but when i convert useing directshows only thing the converts dvb-t h.264 it auto deinterlace i dont even choose the converter to it just dose
    what decoder are you using for directshow? turn off deinterlacing or switch decoders and turn it off
    or use another media player
    i can switch it off sorry it is off but it still deinterlacing im useing no filters i just make a avs file eg
    directshowsource("the simpsons.ts")
    and i just open the avs file in megui and its not intelaced but when i convert it it looks blured because its useing blend how do i stop it
    if you could add me on msn happyfart61@live.com would be much easyer to help me thanks man for help
    Identify what filter and decoder you are using for directshow. Do this by rendering the transport stream in graphstudio or graphedit. Right click the boxes for the decoder for more information (there should be one for deinterlacing)
    If you are encoding, one option is to use another source filter than directshowsource() eg. ffmpegsource2()
    Even better, right click on the main MPC windows while a video is playing and use the Filter option to see which filters are in use (or use Play -> Filters). Select the video decoder and the render to see which is deinterlacing.
    will do now ty
    its says cyberlink avc
    If you're using MPCHC the cyberlink decoder may not be the one that is being used. MPCHC has a built in AVC decoder and can also use the graphics card's DXVA decoder. So it may not be using a DirectShow AVC decoder. Many filters can be configured while they are running using the method I described earlier. Some remember the settings from run to run.
    If it's MPC (NOT MPCHC) , then right click the box in graphstudio where it says cyberlink, and it should give you options to deactivate deinterlacing (I think... I don't use cyberlink)
    wow ill give it a try
    thaqnks guy you fixed it ty
    To help others in the future -- what was your fix?
  1. Deinterlace
    By leftspeaker2000 in forum DVD Ripping
    Last Post: 5th Dec 2011, 05:17
  2. Deinterlace?
    By ZedsDead in forum Video Conversion
    Last Post: 14th Mar 2010, 23:21
  3. To deinterlace or not deinterlace...
    By Nilfennasion in forum Mac
    Last Post: 4th Dec 2008, 00:46
  4. Do I need to deinterlace? Or never deinterlace?
    By rbatty11 in forum Video Conversion
    Last Post: 17th Jan 2008, 13:15
  5. deinterlace with ffmpeg
    By ingemar in forum ffmpegX general discussion
    Last Post: 4th Jun 2007, 00:42
